查看: 1928|回复: 4
做类似于图层的菜单?
发表于 2004-9-16 09:53:00 | 显示全部楼层 |阅读模式
用cad的做菜单的方法有没有办法做类似于图层的菜单?好像很难的。我看到有的开发人员能做到,是不是要用arx技术,能否点拨一二。谢谢
发表于 2004-9-16 10:38:00 | 显示全部楼层
LISP cannot accomplish this.
 楼主| 发表于 2004-9-16 10:56:00 | 显示全部楼层
那有没有办法可以做到象DESIGN CENTER那样的对话框,永远留在CAD 的绘图区的?
发表于 2004-9-16 15:03:00 | 显示全部楼层
唉,可停靠对话框 LISP 也做不出来的
ARX 和 ODCL 可以的
发表于 2004-9-17 15:54:00 | 显示全部楼层
这些是标准的CAD预定义控件
Toolbar control definitions use the keyword Control followed by a name specifying the type of control element requested contained in parentheses.
TAG4 [Control (element)]
The values for the element parameter are as follows (they are not case-sensitive):
_Color
Specifies the color control element. This element is a drop-down list that provides specification of the current color.
_Dimstyle
Specifies the dimension style control element. This element is a drop-down list that provides specification of the current dimension style.
_Layer
Specifies the layer control element. This element is a drop-down list that provides control of the current layers in the drawing.
_Linetype
Specifies the linetype control element. This element is a drop-down list that provides specification of the current linetype.
_Lineweight
Specifies the lineweight control element. This element is a drop-down list that provides specification of the current lineweight.
_PlotStyle
Specifies the plot style control element. This element is a drop-down list that provides specification of the current plot style.
_Refblkname
Specifies the xref name control element. This element displays the current xref name in edit mode.
_UCSManager
Specifies the UCS control element. This element is a drop-down list that provides specification of the current UCS.
_View
Specifies the view control element. This element is a drop-down list that provides specification of the current standard 3D views.
_ViewportScale
Specifies the viewport scale control element. This element is a drop-down list that provides specification of viewport scaling in Layout mode.
GMT+8, 2025-9-30 05:35 , Processed in 0.320981 second(s), 27 queries , Gzip On.
