查看: 3062|回复: 7
批量给圆孔、圆弧画中心线的程序
发表于 2004-9-16 15:29:00 | 显示全部楼层 |阅读模式
(defun C:mc (/ circle-ssget arc-ssget temp-int
temp-entname var-osmode var-layer var-cmdecho
p1 p2 p3 p4
dia-value center-point
(setq var-osmode (getvar "osmode"))
(setq var-layer (getvar "clayer"))
(setq var-cmdecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(if (= (tblsearch "layer" "center") nil)
(command "layer" "new" "center" "color" 1
"center" "ltype" "center" "center" "set"
"center" ""
(command "layer" "set" "center" "")
(setq circle-ssget
(ssget
"c"
(setq p1
(getpoint
"\n您选择框内的所有圆和圆弧都画上中心线。\n 请给出选择框的第一个点:"
(print "请给出选择框的对角点:")
(while (/= 3 (car (setq p2 (grread 1 1 0))))
(redraw)
(grdraw p1 (list (car p1) (nth 1 (cadr p2))) -1 1)
(grdraw p1 (list (nth 0 (cadr p2)) (nth 1 p1)) -1 1)
(grdraw (cadr p2)
-1
1
(grdraw (cadr p2)
(list (nth 0 p1) (nth 1 (cadr p2)))
-1
1
) (setq p2 (cadr p2)) )
'((0 . "circle")) )
(redraw)
(setvar "osmode" 0)
(setq arc-ssget (ssget "c" p1 (cadr p2) '((0 . "arc"))))
(setq temp-int 0)
(if (/= circle-ssget nil)
(repeat (sslength circle-ssget)
(setq temp-entname (ssname circle-ssget temp-int))
(setq center-point (cdr (assoc 10 (entget temp-entname))))
(setq dia-value (cdr (assoc 40 (entget temp-entname))))
(setq dia-value (* 1.3 dia-value))
(setq
p1
(list (car center-point) (- (nth 1 center-point) dia-value))
(setq
p2
(list (car center-point) (+ (nth 1 center-point) dia-value))
(setq p3 (list (- (nth 0 center-point) dia-value)
(setq p4 (list (+ (nth 0 center-point) dia-value)
(command "line" p1 p2 "")
(command "line" p3 p4 "")
(setq temp-int (+ temp-int 1))
(princ) (setq temp-int 0)
(if (/= arc-ssget nil)
(repeat (sslength arc-ssget)
(setq temp-entname (ssname arc-ssget temp-int))
(setq
p1
(setq
p2
(command "line" p3 p4 "") (setq temp-int (+ temp-int 1))
(setvar "osmode" var-osmode)
(command "layer" "set" var-layer "")
(setvar "cmdecho" var-cmdecho)
) 1 该程序可以在你框选内自动识别圆孔、圆弧;
2 该程序将画好的中心线放在CENTER图层里(如果你没有建这个层,命令会自动建立该层),该图层设为中心线层。
刚刚学习用LISP,写得不好,请不要丢西红柿。
发表于 2004-9-16 16:39:00 | 显示全部楼层
发表于 2004-9-16 16:42:00 | 显示全部楼层
我丢一个: 选择圆为何不直接用ssget '((0 . "circle")))?前面加个提示: (prompt "请选择圆...")
(ssget '((0 . "circle"))) 这样不一定采用C的方式,选择方式由用户去决定,还可以多种方式并存,不是更好?
发表于 2004-9-17 04:38:00 | 显示全部楼层
;;重来不用画这个,纯玩玩:),现编一个
  1. (defun c:cenline ( / ss i ocen e pt out2) ;; out 全局.
  2.    (princ "\n画圆心标志,选择标注实体:")
  3.    (vl-cmdf ".undo" "be")
  4.    (setq ss (ssget '((0 . "CIRCLE,ARC")))
  5.   out2 (getdist (strcat "\n线出头长度" (if out (rtos out 2 2) "") ":"))
  6.   i -1
  7.   ocen (getvar "dimcen"))
  8.    (if out2 (setq out out2))
  9.    (while (setq e (ssname ss (setq i (1+ i))))
  10.        (setvar "dimcen" (+ out (cdr (assoc 40 (entget e)))))
  11.        (setq pt (vlax-curve-getstartpoint e))
  12.        (vl-cmdf "dimcenter" (princ (list e pt)))
  13.    )
  14.    (setvar "dimcen" ocen)
  15.    (vl-cmdf ".undo" "e")
  16.    (princ)
  17. )
发表于 2004-9-17 15:42:00 | 显示全部楼层
无痕发表于2004-9-17 4:38:00;;重来不用画这个,纯玩玩:),现编一个 getdist (strcat \"\n线出头长度\"
岂不麻烦?应该改,(按直径的15%比较好)
发表于 2004-9-17 19:28:00 | 显示全部楼层
怎么适合怎么改啦,我不用这个的,也不知道出头长度的通常要求
发表于 2025-2-12 17:51:14 | 显示全部楼层
有批量删除圆孔中心线的插件吗?
发表于 2025-2-12 22:26:07 | 显示全部楼层
;;有!
(defun c:11 (/ ss i circle center radius ssLines line)
  (vl-load-com)
  ;; 提示用户选择多个圆
  (setq ss (ssget '((0 . "CIRCLE"))))  ; 选择所有圆对象
  ;; 检查是否选择了圆
  (if ss
      (setq i 0)  ; 初始化索引
      (setvar "cmdecho" 0);_关闭命令提示
      ;; 遍历选择集中的每个圆
      (repeat (sslength ss)
        (setq circle (ssname ss i))  ; 获取当前圆
        (setq center (cdr (assoc 10 (entget circle))))  ; 获取圆心
        (setq radius (cdr (assoc 40 (entget circle))))  ; 获取半径
        ;; 在圆心 0.1 范围内查找中心线
        (setq ssLines (ssget "_C"
                            (list (- (car center) 0.1) (- (cadr center) 0.1))  ; 左下角点
                            (list (+ (car center) 0.1) (+ (cadr center) 0.1))  ; 右上角点
                            '((0 . "LINE") (6 . "CENTER"))))  ; 只选择中心线
        ;; 检查是否有中心线
        (if ssLines
            ;; 遍历找到的中心线并删除
            (repeat (sslength ssLines)
              (setq line (ssname ssLines 0))  ; 获取当前中心线
              (entdel line)  ; 删除中心线
              (setq ssLines (ssdel line ssLines))  ; 从选择集中删除已删除的线
        (setq i (1+ i))  ; 递增索引
      (setvar "cmdecho" 1);_打开命令提示
      (princ "\n处理完成。")  ; 提示用户处理完成
    (princ "\n未选择任何圆。")  ; 如果没有选择圆,输出提示
  (princ)  ; 静默退出
GMT+8, 2025-4-5 08:44 , Processed in 0.178730 second(s), 26 queries , Gzip On.
