查看: 1305|回复: 0
vb和dwg的问题,help
发表于 2004-9-23 16:39:00 | 显示全部楼层 |阅读模式
欲读取dwg文件里的有关的文字信息 ?的地方是出问题的位置,这段代码不知如何写(vb6) Dim acadapp As AcadApplication
Dim acaddoc As AcadDocument
Dim acadtxt As AcadText
'初始化CAD
'On Error Resume Next
Set acadapp = GetObject(, "AutoCAD.application.16")
If Err Then
Err.Clear
Set acadapp = CreateObject("autocad.application.16")
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
acadapp.Documents.Open ("C:\1.dwg")
Set acaddoc = acadapp.ActiveDocument
'acaddoc.Open ("c:\1.dwg")
acadapp.Visible = False
Dim s As String
Dim i As Integer Dim moSpace As Object ?(就是要读出dwg中textstring的内容)
Set moSpace = acaddoc.ModelSpace ?
Dim ent As AcadEntity
For Each ent In moSpace ?
If ent.ObjectName = "acdbtext" Then ?
Debug.Print acadtxt.TextString ?
End If
Next
acaddoc.Close
GMT+8, 2025-2-22 02:12 , Processed in 0.177364 second(s), 23 queries , Gzip On.
