查看: 1731|回复: 6
[讨论]问题在那里?
发表于 2004-9-27 16:58:00 | 显示全部楼层 |阅读模式
定角度划线: 问题在哪里? (defun C:anL(/ e1 pt ang)
(setq ang (getangle "\n:请输入角度值:"))
(setq pt (getpoint "\nPick start point: "))
(command "line" pt "<"ang)
发表于 2004-9-27 17:12:00 | 显示全部楼层
"<"ang 这样的结果是假设输入20度) Command: line
Specify first point:
Specify next point or [Undo]: <
Point or option keyword required.
Specify next point or [Undo]: 20
Specify next point or [Undo]: 你必须这样: (defun C:anL(/ e1 pt ang)
(command "line" pt (strcat "<" (angtos ang)) ...);后面还得给一点或距离,再回车才算完整
发表于 2004-9-27 17:17:00 | 显示全部楼层
注意LINE后的参数,如果是相对坐标,要用相对坐标的格式,最后还要加双引号.
发表于 2004-9-27 17:18:00 | 显示全部楼层
替楼主完善一下 (defun C:anL(/ e1 pt ang)
(setvar "orthomode" 0)
(setq ang (getangle "\n:输入角度值:"))
(setq dst (getdist pt "\n:输入长度值:"))
(command "line" pt (strcat "@" (rtos dst) "<" (angtos ang)) "")
发表于 2004-9-27 17:22:00 | 显示全部楼层
好象不需要关掉正交吧
发表于 2004-9-27 17:32:00 | 显示全部楼层
meflying发表于2004-9-27 17:22:00好象不需要关掉正交吧
哈哈,的确是"多此一举"
 楼主| 发表于 2004-9-27 20:18:00 | 显示全部楼层
谢谢!
受益匪浅
GMT+8, 2025-2-23 03:03 , Processed in 0.158584 second(s), 25 queries , Gzip On.
