查看: 2748|回复: 3
[求助]用VBA如何调出CAD的颜色属性对话框,之后,如何获得所选的颜色号
发表于 2004-9-29 11:11:00 | 显示全部楼层 |阅读模式
斑竹和各位大侠: 用VBA如何调出CAD的颜色属性对话框,之后,如何获得所选的颜色号。能不能与lisp结合得到呢?请给个例子。谢了!
发表于 2004-9-29 19:20:00 | 显示全部楼层
Reply From: Oquendo, Frank
Date: Jul/13/00 - 18:18 (GMT)
Re: Using the Color Dialog
I don't know about the File dialog (maybe GETFILED will work) but I do know
that you can use the VisualLISP ActiveX Module to call the ACAD_COLORDLG
function and receive its return value. If you're not familiar with the
VisualLISP ActiveX Module, I have a free wrapper class in the download
section of my web site. It's called VLAX (pretty original, huh?) Using it,
you can call the color dialog like so: Dim objVLAX As New VLAX, retVal
retVal = objVLAX.EvalLispExpression("(acad_colordlg 3 nil)") Be sure to add the class module to your project and also be sure to type
(VL-LOAD-COM) at the command line before running.
发表于 2004-9-30 09:58:00 | 显示全部楼层
Private Declare Function acedSetColorDialog Lib _
"acad.exe" (color As Long, ByVal bAllowMetaColor _
As Boolean, ByVal nCurLayerColor As Long) As Boolean Public Function ChooseColor(ByVal lngInitClr As Long, _
ByVal blnMetaColor As Boolean, _
ByVal lngCurClr As Long) As Long
ChooseColor = -1
On Error Resume Next
If acedSetColorDialog(lngInitClr, blnMetaColor, lngCurClr) Then
ChooseColor = lngInitClr
End If
On Error GoTo 0
End Function
参与人数 1威望 +1 金钱 +10 贡献 +10 激情 +10 收起 理由
雪山飞狐_lzh + 1 + 10 + 10 + 10 【好评】好程序
 楼主| 发表于 2004-9-30 10:11:00 | 显示全部楼层
谢了!
GMT+8, 2025-5-28 01:23 , Processed in 0.162638 second(s), 24 queries , Gzip On.
