查看: 2339|回复: 5
斑竹看看这个链接为何不能用了?VLAX类
发表于 2004-9-29 11:58:00 | 显示全部楼层 |阅读模式
斑竹大人 ,不得不在麻烦你一下。我现在需要 vlax类 ,本站有如下链接 http://bbs.mjtd.com/forum.php?mod=viewthread&tid=9328 但是现在不能下载,斑竹可否重新激活链接,让小弟下载一次。 小弟 先谢了~~
发表于 2004-9-29 12:03:00 | 显示全部楼层
看看10楼的发言
 楼主| 发表于 2004-9-29 12:41:00 | 显示全部楼层
斑竹关键是我现在大不开代码,怎么拷贝呢? 十楼的发言 偶已经看了。
麻烦 多指点~···
发表于 2004-9-29 13:15:00 | 显示全部楼层
初级用户是不能看见,:) ' VLAX.CLS v2.0 (Last updated 8/1/2003)
' Copyright 1999-2001 by Frank Oquendo
' 该程序由明经通道修改支持2004版本
' http://www.mjtd.com
' Permission to use, copy, modify, and distribute this software
' for any purpose and without fee is hereby granted, provided
' that the above copyright notice appears in all copies and
' that both that copyright notice and the limited warranty and
' restricted rights notice below appear in all supporting
' documentation.
' FRANK OQUENDO (THE AUTHOR) PROVIDES THIS PROGRAM "AS IS" AND WITH
' ALL FAULTS. THE AUTHOR SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY
' OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. THE AUTHOR
' DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
' UNINTERRUPTED OR ERROR FREE.
' Use, duplication, or disclosure by the U.S. Government is subject to
' restrictions set forth in FAR 52.227-19 (Commercial Computer
' Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
' (Rights in Technical Data and Computer Software), as applicable.
' VLAX.cls allows developers to evaluate AutoLISP expressions from
' Visual Basic or VBA
' Notes:
' All code for this class module is publicly available througout various posts
' at news://discussion.autodesk.com/autodesk.autocad.customization.vba. I do not
' claim copyright or authorship on code presented in these posts, only on this
' compilation of that code. In addition, a great big "Thank you!" to Cyrille Fauvel
' demonstrating the use of the VisualLISP ActiveX Module.
' Dependencies:
' Use of this class module requires the following application:
' 1. VisualLISP Private VL As Object
Private VLF As Object Private Sub Class_Initialize() If Left(ThisDrawing.Application.Version, 2) = "15" Then
Set VL = GetInterfaceObject("VL.Application.1")
ElseIf Left(ThisDrawing.Application.Version, 2) = "16" Then
Set VL = GetInterfaceObject("VL.Application.16")
End If
Set VLF = VL.ActiveDocument.Functions
End Sub Private Sub Class_Terminate() Set VLF = Nothing
Set VL = Nothing End Sub Public Function EvalLispExpression(ByVal lispStatement As String) Dim sym As Object, ret As Object, retval
Set sym = VLF.Item("read").funcall(lispStatement)
On Error Resume Next
retval = VLF.Item("eval").funcall(sym)
If Err Then
EvalLispExpression = ""
Else
EvalLispExpression = retval
End If End Function Public Sub SetLispSymbol(ByVal symbolName As String, ByVal Value) Dim sym As Object, ret, symvalue
symvalue = Value
Set sym = VLF.Item("read").funcall(symbolName)
ret = VLF.Item("set").funcall(sym, symvalue)
EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
EvalLispExpression "(setq translate-variant nil)" End Sub Public Function GetLispSymbol(ByVal symbolName As String) Dim sym As Object, ret, symvalue
symvalue = Value
GetLispSymbol = VLF.Item("eval").funcall(sym) End Function Public Function GetLispList(ByVal symbolName As String) As Variant Dim sym As Object, list As Object
Dim Count, elements(), i As Long
Set list = VLF.Item("eval").funcall(sym)
Count = VLF.Item("length").funcall(list)
ReDim elements(0 To Count - 1) As Variant
For i = 0 To Count - 1
elements(i) = VLF.Item("nth").funcall(i, list)
Next
GetLispList = elements
End Function Public Sub NullifySymbol(ParamArray symbolName()) Dim i As Integer
For i = LBound(symbolName) To UBound(symbolName)
EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
Next End Sub
 楼主| 发表于 2004-9-29 15:06:00 | 显示全部楼层
多谢斑竹~~ 斑竹节日快乐!
发表于 2007-3-15 21:57:00 | 显示全部楼层
好东东,最近准备用VBA了
GMT+8, 2025-2-22 18:29 , Processed in 0.164061 second(s), 23 queries , Gzip On.
