查看: 1453|回复: 2
这段代码哪里有问题,为什么不能显示!!!!!!!!!!
发表于 2004-10-7 16:33:00 | 显示全部楼层 |阅读模式
int i; AcDbObjectId lineId;
AcDbObjectId ptId;
AcGePoint3d Pt; AcDb3dPolyline *pLine = new AcDb3dPolyline(); AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()
->getSymbolTable(pBlockTable, AcDb::kForRead); AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,
AcDb::kForWrite);
pBlockTable->close();
for(i=1;i<=10;i++)
Pt.x=i;
Pt.y=i*rand();
Pt.z=0.0;
AcDb3dPolylineVertex *pV=new AcDb3dPolylineVertex(Pt);
pLine->appendVertex(ptId,pV);
pBlockTableRecord->appendAcDbEntity(lineId, pLine);
pBlockTableRecord->close();
pLine->close();
发表于 2004-10-7 19:07:00 | 显示全部楼层
参考: void getUcsToWcsMatrix(AcGeMatrix3d& m, AcDbDatabase* db)
ASSERT(db != NULL); if (!acdbUcsMatrix(m, db)) {
m.setToIdentity();
ASSERT(0);
} void ucsToWcs(AcGePoint3dArray& ptArray)
AcDbDatabase* db = acdbHostApplicationServices()->workingDatabase();
ASSERT(db != NULL); AcGeMatrix3d m;
getUcsToWcsMatrix(m, db); int len = ptArray.length();
for (int i=0; i<len; i++)
ptArray = m * ptArray;
} // ----- asdktest._test command (do not rename)
static void asdktest_test(void)
// Add your code for command asdktest._test here
AcDbObjectId ptId;
AcGePoint3d Pt; AcDb3dPolyline *pLine; AcDbBlockTable *pBlockTable;
acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBlockTable, AcDb::kForRead); AcDbBlockTableRecord *pBlockTableRecord;
pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,AcDb::kForWrite);
pBlockTable->close(); AcGeMatrix3d ucsToWcsMat; acdbUcsMatrix(ucsToWcsMat); AcGePoint3dArray vertices; for(i=1;i<=10;i++)
Pt.x=i;
Pt.y=i;
Pt.z=0.0;
vertices.append(Pt);
} pLine = new AcDb3dPolyline(AcDb::k3dSimplePoly, vertices);
pLine->setDatabaseDefaults();
pLine->close();
 楼主| 发表于 2004-10-8 08:54:00 | 显示全部楼层
成功了,非常感谢!
GMT+8, 2025-2-23 14:46 , Processed in 0.161078 second(s), 24 queries , Gzip On.
