查看: 1683|回复: 3
关于遍历的问题
发表于 2004-10-14 14:08:00 | 显示全部楼层 |阅读模式
今天看书又遇到问题了!! '(2)向选择集中添加对象
'设置选择过滤器
Dim FilterType(0 To 5) As Integer
Dim FilterData(0 To 5) As Variant
FilterType(0) = -4
FilterData(0) = "<or" '逻辑运算符的开始,表示一个或多个运算对象
FilterType(1) = 0 ----‘0’是什么意思,还有别的取值吗
FilterData(1) = "Arc"
FilterType(2) = 0
FilterData(2) = "Circle"
FilterType(3) = 0
FilterData(3) = "Spline"
FilterType(4) = 0
FilterData(4) = "Line"
FilterType(5) = -4
FilterData(5) = "or>" '逻辑运算符的结束
版主能给解释一下上面的语句吗
'使用All的选择模式
SSet.Select acSelectionSetAll, , , FilterType, FilterData
'(3)遍历其中的对象
Dim element As AcadEntity
For Each element In SSet
If element.ObjectName = "AcDbCircle" Or element.EntityType = acArc Then
element.color = acRed
End If
Next 我在cad中画了直线、圆、弧可是运行代码后什么都没了??? 我想获得下图曲线于直线的交点该怎么做了?
发表于 2004-10-14 16:10:00 | 显示全部楼层
Sub ttt()
On Error Resume Next
Dim ss As AcadSelectionSet
Dim ft(0) As Integer, fd(0)
ft(0) = 0: fd(0) = "Arc,Circle,Spline,Line"
ThisDrawing.SelectionSets("TTT").Delete
Set ss = ThisDrawing.SelectionSets.Add("TTT")
ss.Select acSelectionSetAll, , , ft, fd
For Each element In ss
If element.ObjectName = "AcDbCircle" Or element.ObjectName = "AcDbArc" Then
element.Color = acRed
End If
Next
End Sub
发表于 2004-10-16 00:06:00 | 显示全部楼层
'0'代表DXF组码, 对就实体类型, 如果你用 (entget (car (entsel))) 这一lisp请句选择一个"LINE"对象, 命令窗口会有如下信息: Command: (entget (car (entsel))) Select object: ((-1 . <Entity name: 7ef51f68>) (0 . "LINE") (330 . <Entity
name: 7ef51cf8>) (5 . "E5") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"0") (100 . "AcDbLine") (10 422.463 449.338 0.0) (11 974.845 698.167 0.0) (210
0.0 0.0 1.0)) 如果选择一个"TEXT"对象呢? Command: (entget (car (entsel))) Select object: ((-1 . <Entity name: 7ef51f70>) (0 . "TEXT") (330 . <Entity
name: 7ef51cf8>) (5 . "E6") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"0") (100 . "AcDbText") (10 660.496 349.444 0.0) (40 . 2.5) (1 . "HELLO") (50 .
0.0) (41 . 1.0) (51 . 0.0) (7 . "Standard") (71 . 0) (72 . 0) (11 0.0 0.0 0.0)
(210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0)) 不同的对象数据信息不同, 但会有通用的组码: 比如 0 - 类型 8 - 图层 ...
发表于 2004-10-18 11:30:00 | 显示全部楼层
关于取得直线河等高线的交点问题:看过以前各斑主的解答,先取得一条等高线的高程,然后改变直线的高程与等高线高程相同,主要是让直线和等高线共面,最后用InterSectWith函数求出交点
GMT+8, 2025-5-28 08:34 , Processed in 0.170213 second(s), 30 queries , Gzip On.
