查看: 2562|回复: 2
求教:简单的求两直线交点的代码
发表于 2004-10-15 10:07:00 | 显示全部楼层 |阅读模式
请大家指教,我想要两条直线的交点,请问有这样的命令吗?或者有简单些的代码吗?
发表于 2004-10-15 10:18:00 | 显示全部楼层
Finds the intersection of two lines
(inters pt1 pt2 pt3 pt4 [onseg])
All points are expressed in terms of the current UCS. If all four point arguments are 3D, inters checks for 3D intersection. If any of the points are 2D, inters projects the lines onto the current construction plane and checks only for 2D intersection.
Arguments
pt1
One endpoint of the first line.
pt2
The other endpoint of the first line.
pt3
One endpoint of the second line.
pt4
The other endpoint of the second line.
onseg
If specified as nil, the lines defined by the four pt arguments are considered infinite in length. If the onseg argument is omitted or is not nil, the intersection point must lie on both lines or inters returns nil.
Return Values
If the onseg argument is present and is nil, inters returns the point where the lines intersect, even if that point is off the end of one or both of the lines. If the onseg argument is omitted or is not nil, the intersection point must lie on both lines or inters returns nil. The inters function returns nil if the two lines do not intersect.
Examples
(setq a '(1.0 1.0) b '(9.0 9.0))
(setq c '(4.0 1.0) d '(4.0 2.0))
Command: (inters a b c d)
nil
Command: (inters a b c d T)
nil
Command: (inters a b c d nil)
(4.0 4.0)
 楼主| 发表于 2004-10-15 15:01:00 | 显示全部楼层
好长呀,嘿嘿,谢谢拉
GMT+8, 2025-3-12 10:28 , Processed in 0.177628 second(s), 25 queries , Gzip On.
