查看: 1588|回复: 1
怎样在Lisp中读下列程序??急急急
发表于 2004-10-15 16:32:00 | 显示全部楼层 |阅读模式
(defun C:MyCreatePassword( / PCCode ADcode MPass)
(setq PCCode (GETSTRING "\n Please input the computer code:\t"))
;CCode是客户机器上读出的机器码
(setq ADCode (GETSTRING "\n Please input the Additional code (12digit) such as \
123456789123\n The Additional code must be same as you have wrote in the software\
sent to your client\t:"))
;;ADCode是用来生成密码的,一定要确保在客户的机器上也使用了相同的ADCode
(setq MPass (create_product_password ADCode PCCode))
(alert (strcat "the Password for this PC-Code is : " MPass))
(PRINC)
lisp是开发工具吗,我下载的visual lisp for AutoCAD r14装到机器上后,但找不到,请高手帮我解决!!
发表于 2004-10-15 17:06:00 | 显示全部楼层
不用找,在CAD的命令行输入:vlisp
上面的这段程序不完整,无法正确运行的
GMT+8, 2025-3-12 10:22 , Processed in 0.160423 second(s), 26 queries , Gzip On.
