查看: 2201|回复: 4
怎么让popup_list框能输入数据
发表于 2004-10-16 21:46:00 | 显示全部楼层 |阅读模式
怎么让popup_list框能象文本框一样,也能输入数据。
应该设置popup_list的什么属性,或要什么lisp驱动程序。
发表于 2004-10-16 21:49:00 | 显示全部楼层
Use DosLib dos_editlist function
 楼主| 发表于 2004-10-17 21:18:00 | 显示全部楼层
好象没有dos_editlist这个控件,能具体说怎么用吗。谢谢。我是初学者,希望能写详细点,谢谢!
发表于 2004-10-18 05:17:00 | 显示全部楼层
你要下载DOSLIB
dos_editlist
Displays a sizeable Windows dialog box with an editable list box. Items can be added or removed from the list, and the order of the list can be changed.
Syntax
(dos_editlist title prompt list)
Parameters
title A string containing the dialog box title.
path A string containing the dialog box prompt.
list A list of string values.
Returns
A list of string items selected from the list if successful. nil on cancel or on error.
Examples
Command: (dos_editlist "Edit Items" "Add, remove, or edit items" '("Item1" "Item2" "Item3")) MSITStore:C:\Documents%20and%20Settings\Ivy\桌面\doslib61.chm::/images/dos_editlist.jpg" width=347 border=0> ("Item1" "Item2" "Item3" "NewItem4")
Also See
MSITStore:C:\Documents%20and%20Settings\Ivy\桌面\doslib61.chm::/Graphical_User_Interface_Functions/dos_checklist.htm" target="_blank" >dos_checklist, MSITStore:C:\Documents%20and%20Settings\Ivy\桌面\doslib61.chm::/Graphical_User_Interface_Functions/dos_proplist.htm" target="_blank" >dos_proplist
发表于 2013-7-28 14:13:19 | 显示全部楼层
不用插件实现不了吗
GMT+8, 2025-5-28 01:57 , Processed in 0.190151 second(s), 25 queries , Gzip On.
