查看: 1478|回复: 6
大家帮忙看一下,这个程序错在哪里?
发表于 2004-10-27 18:52:00 | 显示全部楼层 |阅读模式
以下是自动连线的程序,就是能过输入点号用PL线连接相应的点,但是执行后只能连第一个点,接下去就出错了 (defun c:PL (/ str)
(VL-LOAD-COM) (setq AcadObject(vlax-get-acad-object) AcadDocument(vla-get-ActiveDocument AcadObject) mSpace(vla-get-ModelSpace AcadDocument) )
(fen)
(if (/= zb nil)
(command "_pline" zb))
(defun fen ()
(setq a (getstring "输入点号:"))
(setq sel (ssget "_x" '((0 . "TEXT"))))
(setq n (sslength sel))
(setq i 0)
(while (< i n)
(setq sf (entget (ssname sel i)))
(setq dianhao(cdr (assoc 1 sf)))
(if (= dianhao a)
(progn(setq zuobiao(cdr (assoc 10 sf)))
(setq zbX(-(car zuobiao) 0.5))
(setq zbY(+(car(cdr zuobiao)) 0.75))
(setq zb(list zbX zbY))
(setq i (+ i 1))
发表于 2004-10-28 08:30:00 | 显示全部楼层
给个调试图先,或者说说运行这样的程序需要什么条件
 楼主| 发表于 2004-10-28 19:01:00 | 显示全部楼层
也没其它什么条件,就是通过输入点号,然后程序找到它,并用PL线把其按照输入的顺序给连起来
发表于 2004-10-29 08:27:00 | 显示全部楼层
也不知道你上面的程序是哪儿抄来改的,,,这样可学不好,弄一个程序来至少要把它大致看明白了
  1. (defun c:PL (/ str)
  2.    (VL-LOAD-COM)
  3.    (fen)
  4.    (if zb
  5.        (progn
  6.            (command "_pline")
  7.            (mapcar 'command zb)
  8.            (command "")
  9.        )
  10.    )
  11.    (princ)
  12. )(defun fen ()
  13.    (setq b nil)
  14.    (while (/= (setq a (getstring "输入点号:")) "")
  15.        (setq b (append b (list a)))
  16.    )
  17.    (setq i 0 zb nil)
  18.    (repeat (length b)
  19.        (setq dianhao (nth i b))
  20.        (setq ent (ssname (ssget "x" (list '(0 . "TEXT") (cons 1 dianhao))) 0))
  21.        (setq sf (entget ent))
  22.        (if (member dianhao b)
  23.            (progn(setq zuobiao(cdr (assoc 10 sf)))
  24.                    (setq zbX(-(car zuobiao) 0.5))
  25.                    (setq zbY(+(car(cdr zuobiao)) 0.75))
  26.                    (setq zb(append zb (list (list zbX zbY))))
  27.            )
  28.        )
  29.        (setq i (+ i 1))
  30.    )
  31.    zb
  32. )
发表于 2004-10-29 16:38:00 | 显示全部楼层
  1. ;;那些点似乎是多余的(defun C:PL (/ LST A)
  2.    (setvar "osmode" 0)
  3.    (setq LST (FEN))
  4.    (command "_.pline")
  5.    (while (and (setq A (getstring "输入点号: "))
  6.              (assoc A LST)
  7.    )
  8.        (command (cadr (assoc A LST)))
  9.    )
  10.    (command "")
  11.    (princ)
  12. )(defun FEN (/ LST SEL N I SF DIANHAO ZUOBIAO ZBX ZBY ZB)
  13.    (setq SEL (ssget "_x" '((0 . "TEXT"))))
  14.    (setq N (sslength SEL))
  15.    (setq I 0)
  16.    (while (< I N)
  17.        (setq SF (entget (ssname SEL I)))
  18.        (setq DIANHAO (cdr (assoc 1 SF)))
  19.        (setq ZUOBIAO (cdr (assoc 10 SF)))
  20.        (setq ZBX (- (car ZUOBIAO) 0.5))
  21.        (setq ZBY (+ (car (cdr ZUOBIAO)) 0.75))
  22.        (setq ZB (list ZBX ZBY))
  23.        (setq LST (cons (list DIANHAO ZB) LST))
  24.        (setq I (+ I 1))
  25.    )
  26.    LST
  27. )
 楼主| 发表于 2004-10-29 20:07:00 | 显示全部楼层
我并没有改它,是论坛上的一个朋友给我写的
 楼主| 发表于 2004-10-29 20:12:00 | 显示全部楼层
太感谢你们俩了,真的谢谢
GMT+8, 2025-2-19 06:59 , Processed in 0.195689 second(s), 26 queries , Gzip On.
