查看: 2443|回复: 2
求助Acme CAD Converter 4.32 汉化版的注册码
发表于 2004-10-29 15:39:00 | 显示全部楼层 |阅读模式
有谁知道
Acme CAD Converter 4.32 汉化版的注册码?
发表于 2004-12-24 14:11:00 | 显示全部楼层
到哪找Acme CAD Converter 4.60汉化版的注册码,谁有能贴一下吗?
发表于 2008-11-30 02:49:00 | 显示全部楼层
--RELEASE INFO----------------
Release......: Acme.CAD.Converter.v7.80.WinAll.Incl.Key-DEC0DE
Release Date.: 09/08/07
Cracker......: DEC0DER / DEC0DE CRACKER TEAM
Protection...: SERIAL
Patcher......: N0Ne
Website......: http://www.dwgtool.com/
Files........: 01 x 3.1mb
FileNames....: dcacc780.zip
OS...........: WinAll
Software Cost: $79.95
--Release Notes--------------
Acme CADConverter is a format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF, JPEG, WMF, PCX, TIFF, PNG, TGA, DXF, DWG, SVG, SVGZ, CGM, EPS, PDF, HPGL(PLT,HGL) etc., and also enable the conversion between DXF and DWG file versions (AutoCAD R2.5-R2008).Supports replace font file. Supports Transmit command like AutoCAD,and batch recover drawing files. It can export layers of DWG file to the layers of PDF file and it can export OLE entity and raster entity into PDF file.
--Install-Notes------------
1. Unpack
2. Run/Install acmecadsetup.exe
3. Register with this serial
Serial.: 627HUTHN3P76XP9NRVSB1Z04KTX3IJT3R4MF9CZ24C8M1GJQRVP0VDQNZX14
Enjoy..
--Group-Notes--------------
In need of...:
. Affil sites.
. 0ther scene stuff
. ASCii dudes, make us a nice nfo :)
Contact..: dec0deteam2007@gmail.com - We will answer you :), just mail us....
-- Greetings! ---
NT
The guys that made us scene..
0ther groups we thx for the work they do: ARN - TBE - CRD - XFORCE - YAG - mVs - PUKKA
Scene ftw..
- DEC0DE TEAM 2007 - NFO by DEC0DER
GMT+8, 2025-5-24 22:01 , Processed in 0.175361 second(s), 29 queries , Gzip On.
