查看: 2413|回复: 5
怎么一加载CAD就死了?
发表于 2004-11-1 10:30:00 | 显示全部楼层 |阅读模式
只要加载,CAD就没有响应,为何呀!
  1. ;简单的法兰绘制  (defun c:falan(/ dcl_id x y n1 n rd a a1 rj rx cp pt d)
  2.    (setq dcl_id (load_dialog "falan.dcl"))
  3.    (if (not (new_dialog "falan" dcl_id))
  4.    (exit)
  5.    )
  6.    (action_tile "kaishi" "(message)")
  7.    (draw)
  8.    (start_dialog)
  9.    (unload_dialog dcl_id)
  10.    (princ)
  11.   )
  12.    (defun draw()
  13.    (command "circle" cp rd)
  14.    (command "circle" cp rx)
  15.    (command "circle" pt "d" d)    (command "array" "1" "" "p" cp n1 "" "y")
  16.    (command "circle" cp rj)
  17.    )
  18.      (defun message()
  19.    (setq x(atof(get_tile "x")))
  20.    (setq y(atof(get_tile "y")))
  21.    (setq cp(list x y))
  22.    (setq rd(atof(get_tile "wai")))
  23.    (setq rx(atof(get_tile "fayuan")))
  24.    (setq rj(atof(get_tile "jieyuan")))
  25.    (setq d(atof(get_tile "zhijing")))
  26.    (setq n1(atoi(get_tile "shuliang")))
  27.    (setq n(float n1))
  28.    (setq a1(atof(get_tile "du")))
  29.    (setq a(* pi(/ a1 180)))
  30.    (setq pt(polar cp a rj))
  31.    )
  1. falan:dialog{
  2. label="头标题";
  3. :text{
  4. label="wenzi";
  5. }:boxed_row{
  6. label="中心坐标";
  7. :edit_box{
  8. label="x=";
  9. key="x";
  10. fixed_width=true;
  11. alignment=centered;
  12. width=5;
  13. }
  14. :edit_box{
  15. label="y=";
  16. key="y";
  17. fixed_width=true;
  18. alignment=centered;
  19. width=5;
  20. }
  21. }:boxed_row{
  22. label="尺寸";
  23. :edit_box{
  24. label="wai";
  25. key="wai";
  26. fixed_width=true;
  27. alignment=centered;
  28. width=5;
  29. }
  30. :edit_box{
  31. label="fayuan";
  32. key="fa";
  33. fixed_width=true;
  34. alignment=centered;
  35. width=5;
  36. }
  37. :edit_box{
  38. label="jieyuan";
  39. key="jie";
  40. fixed_width=true;
  41. alignment=centered;
  42. width=5;
  43. }
  44. }
  45. :boxed_row{
  46. label="canshu";
  47. :edit_box{
  48. label="zhijing";
  49. key="zhijing";
  50. fixed_width=true;
  51. alignment=centered;
  52. width=5;
  53. }
  54. :edit_box{
  55. label="shuliang";
  56. key="shuliang";
  57. fixed_width=true;
  58. alignment=centered;
  59. width=5;
  60. }
  61. :edit_box{
  62. label="du";
  63. key="du";
  64. fixed_width=true;
  65. alignment=centered;
  66. width=5;
  67. }
  68. }:boxed_row{
  69. :button{
  70. key="kaishi";
  71. label="kaishi";
  72. fixed_width=true;
  73. width=5;
  74. }
  75. ok_only;
  76. }
  77. }
发表于 2004-11-1 10:49:00 | 显示全部楼层
(exit)
(draw) ;; <<-----Here, you try to run commands before (start_dialog)!
(start_dialog)
 楼主| 发表于 2004-11-1 11:28:00 | 显示全部楼层
谢谢斑竹,我改了,也运行起来了,不知道为何要放在后面?
出现了错误: 参数类型错误: stringp nil,我知道是:是需要字符串参数的地方给了个nil,导致错误,但我真的不知道在哪里啊!
发表于 2004-11-1 12:05:00 | 显示全部楼层
可能是数据类型有误吧
 楼主| 发表于 2004-11-1 12:25:00 | 显示全部楼层
很努力的寻找,无果……
发表于 2004-11-1 13:05:00 | 显示全部楼层
Some of the keys in LISP file do not match those in your DCL file
GMT+8, 2025-7-6 12:06 , Processed in 0.186693 second(s), 25 queries , Gzip On.
