查看: 3366|回复: 7
请高手们帮忙解决这LISP为何在2004里运用
发表于 2004-11-9 19:24:00 | 显示全部楼层 |阅读模式
;;; EXTRIM.LSP - Written by Randy Kintzley
;;; Copyright (C) 1997 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;;;;;;;;;;;;;;;;;;;;;;;;;;;GLOBAL INFO.;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;Functions created as result of loading file: extrim.lsp
; ANOTHER_OFFSET
; ETRIM
; GET_FENCE_POINTS
; INTERSECT_CHECK
; TRUNCATE_2_VIEW
;Variables created as result of loading file: extrim.lsp
;Functions created as a result of executing the commands in: extrim.lsp
;Variables created as a result of executing the commands in: extrim.lsp
; BONUS_ALIVE
; BONUS_OLD_ERROR
;Extended-TRIM - cookie-cutter routine
;Select a polyline, line, circle or arc and a side to trim on
(defun c:et ( / dxf na p1 redraw_it) (if (and (not init_bonus_error)
(equal -1 (load "ac_bonus.lsp" -1))
);and
(progn (alert "Error:\n Cannot find AC_BONUS.LSP.")(exit))
);if
(init_bonus_error (list
(list "cmdecho" 0
"highlight" 0
"regenmode" 1
"osmode" 0
"ucsicon" 0
"offsetdist" 0
"attreq" 0
"plinewid" 0
"plinetype" 1
"gridmode" 0
"celtype" "CONTINUOUS"
T ;flag. True means use undo for error clean up.
'(if redraw_it (redraw na 4))
);list
);init_bonus_error ;local function
(defun dxf (a b / ) (cdr (assoc a b)));defun (princ "\nPick a POLYLINE, LINE, CIRCLE, or ARC for cutting edge..")
(setq na (single_select '((-4 . "<OR")
(0 . "CIRCLE")
(0 . "ARC")
(0 . "LINE")
(0 . "LWPOLYLINE")
(-4 . "<AND")
(0 . "POLYLINE")
(-4 . "<NOT")
(-4 . "&")
(70 . 112)
(-4 . "NOT>")
(-4 . "AND>")
(-4 . "OR>")
T
);single_select
);setq
(if na
;(setq e1 (entget na));;setq
(redraw na 3)
(setq redraw_it T) (setq p1 (getpoint "\nPick the side to trim on:"));setq
(redraw na 4)
(setq redraw_it nil) (if p1 (etrim na p1));if
);progn
);if (restore_old_error)
);defun c:extrim ;!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
;Entity-TRIM function
;takes: na - entity name
; a - a point, the side to trim on
;NOTE: This function does not allow for the possible miss of
; non-continuous linetypes.
(defun etrim ( na a / la dxf b d e1 lst lst2 n j k m ss na2 na3 na4
x y z flag flag2 flag3
) ;local function
(defun dxf (a b / ) (cdr (assoc a b)));defun (setq e1 (entget na));setq
(if (or (setq flag (equal (dxf 0 e1) "POLYLINE"))
(setq flag (equal (dxf 0 e1) "LWPOLYLINE"))
(equal (dxf 0 e1) "LINE")
(equal (dxf 0 e1) "CIRCLE")
(equal (dxf 0 e1) "ARC")
);or
(if (and flag
(equal 8 (logand 8 (dxf 70 e1)))
);and
(setq flag nil)
);if
(setq a (trans a 1 0));setq
(command "_.ucs" "_View")
(setq lst (ep_list na nil) ;;;find extents of selected cutting edge object
lst (maxminpnt lst)
x (- (car (cadr lst)) (car (car lst)))
y (- (cadr (cadr lst)) (cadr (car lst)))
x (* 0.075 x)
y (* 0.075 y)
z (list x y)
x (list (+ (car (cadr lst)) (car z))
(+ (cadr (cadr lst)) (cadr z))
);list
y (list (- (car (car lst)) (car z))
(- (cadr (car lst)) (cadr z))
);list
);setq
(command "_.zoom" "_w" x y)
(entupd na) ;;;update the ent. so it's curves display smoothly (setq lst (ep_list na
(/ (pixel_unit) 2.0)
);setq
(if (or (not flag)
(not (p_isect lst nil))
);or
(progn ;then the object is valid and not a self intersecting polyline.
(if (and flag
(equal (car lst) (last lst) 0.0001)
);and
(setq flag3 T);then the polyline could potentialy need a second offset
);if
(if (setq la (b_layer_locked (getvar "clayer")))
(command "_.layer" "_unl" (getvar "clayer") "")
);if
(command "_.pline")
(setq b nil)
(setq n 0);setq
(repeat (length lst)
(setq d (nth n lst))
(if (not (equal d b 0.0001))
(command d)
(setq lst2 (append lst2 (list d)));setq
(setq b d);setq
);progn
);if
(setq n (+ n 1))
);repeat
(command "")
(setq na2 (entlast)
ss (ssadd)
ss (ssadd na2 ss)
lst nil
);setq
(ss_visible ss 1)
(setq lst2 (get_fence_points na2 a lst2 flag3 flag));setq
(if la
(command "_.layer" "_lock" (getvar "clayer") "")
);if
(command "_.ucs" "_p")
;Move the ents to force a display update of the ents to avoid viewres problems.
(setvar "highlight" 0)
(if (setq ss (ssget "f" (last lst2)))
(command "_.move" ss "" "0,0,0" "0,0,0")
);if
(if flag
(if (setq la (b_layer_locked (dxf 8 e1)))
(command "_.layer" "_unl" (dxf 8 e1) "")
);if
(ucs_2_ent (dxf 210 e1))
(command "_.copy" na "" "0,0,0" "0,0,0")
(entdel na)
(setq na3 na
na (entlast)
);setq
(command "_.pedit" na "_w" "0.0" "_x")
(if la (command "_.layer" "_lock" (dxf 8 e1) ""));if
);progn
);if
(command "_.trim" na "")
(setq m (- (length lst2) 1));setq
(setq k 0) ;@rk
(repeat (length lst2)
(setq lst (nth k lst2))
(setq a (trans (car lst) 0 1))
(setq n 1)
(repeat (- (length lst) 1) ;repeat each fence list
(setq b (trans (nth n lst) 0 1))
(if (equal a b 0.0001)
(setq flag2 T)
(setq flag2 nil)
);if
(setq na4 nil);setq
(setq j 0);setq
(while (not flag2) ;repeat each segment of the fence until no new ents are created.
(setq na4 (entlast));setq
(command "_F" a b "")
(if (and (equal na4 (entlast))
(or (not (equal k m))
(> j 0)
);or
);and
(setq flag2 T)
);if
(setq j (+ j 1));setq
);while
(setq a b);setq
(setq n (+ n 1));setq
);repeat
(setq k (+ k 1))
);repeat
(command "")
(if flag
);if
(entdel na) ;get rid of the copy
(entdel na3);bring back the original
);progn
);if
);progn
(princ "\nSelf intersecting edges are not acceptable.")
);progn else invalid self intersecting polyline
);if
(command "_.zoom" "_p")
);progn then it's a most likely a valid entity.
);if
);defun etrim ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun another_offset ( pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4 / na ss lst da1 da2) (setq da1 (abs (- a2 a1)));setq
(setq da2 (- (* b (max pl2 pl1))
(/ (* b (abs (- pl2 pl1)))
2.0
);setq
(if (> (abs (- da2 da1))
(* 0.01 (max a1 a2))
(progn (pline (list lst2))
(setq na (entlast)
na2 (entlast)
ss (ssadd)
ss (ssadd na ss)
);setq
(ss_visible ss 1)
(command "_.offset" b na2 a "")
(if (and (not (equal na (entlast)))
(setq lst3 (vtlist (entlast)))
(setq lst3 (intersect_check lst2 lst3 lst4))
);and
(ss_visible (ssadd (entlast) (ssadd)) 1)
(command "_.area" "_ob" (entlast))
(setq pl2 (getvar "perimeter")
a2 (getvar "area")
);setq
(setq lst (list (vtlist (list (entlast) 0))));setq
(entdel (entlast));then offset was a success so delete the ent after getting it's info
);progn then
(if (not (equal na (entlast))) (entdel (entlast)));if else
);if
(entdel na2)
);progn then let's do that second offset
);if lst
);defun another_offset ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun get_fence_points ( na2 a lst2 flag plflag / a1 a2 pl1 pl2 b c d n
lst lst2 lst3 lst4 na
) (if flag
(setq lst2 (cdr lst2));setq
(repeat (fix (/ (length lst2) 2))
(setq lst2 (append (cdr lst2) (list (car lst2)));append
);setq
);repeat
(setq lst2 (append lst2 (list (car lst2))));setq
(command "_.area" "_ob" na2)
(setq pl1 (getvar "perimeter")
a1 (getvar "area")
);setq
);progn
);if (setq a (trans a 0 1)
b (* (getvar "viewsize") 0.05);initial offset distance
n 3.0 ;number of offsets
d (/ b (- n 1)) ;delta offset
c (pixel_unit)
lst4 (viewpnts)
);setq (while (> b c)
(setq na (entlast))
(or (not plflag)
);or
);and
(setq lst3 (lsttrans lst3 1 0))
(if flag
a2 (getvar "area")
);setq
);progn
);if
(setq lst (append lst (list lst3)));setq
(entdel (entlast)) ;delete the ent after getting it's vertex info
(if flag
(another_offset pl1 pl2 a1 a2 b na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then offset was a success
);if
(setq b (- b d));setq
);while
(setq na (entlast))
(command "_.offset" c na2 a "")
(or (not plflag)
);or
);and
(if flag
a2 (getvar "area")
);setq
);progn
);if
(if flag
(another_offset pl1 pl2 a1 a2 c na2 lst2 a lst3 lst4)
);append
);setq
);if
);progn then
);if
(entdel na2) lst
);defun get_fence_points ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
;returns a list of points on screen if the first two lists do not
;contain segments that intersect each other.
(defun intersect_check ( lst lst2 lst3 / x x2 y y2 lst4 flag len len2
a aa b bb c d n j) (setq len (length lst)
len2 (length lst2)
x (car (car lst3))
x2 (car (cadr lst3))
y (cadr (car lst3))
y2 (cadr (cadr lst3))
);setq (setq n 0);setq
(while (and (not flag)
(< (+ n 1) len2)
);and
(setq aa (nth n lst2)
bb (nth (+ n 1) lst2)
a (truncate_2_view aa bb x y x2 y2)
b (truncate_2_view bb aa x y x2 y2)
lst4 (append lst4 (list a))
);setq
(if (or (not (equal a aa))
(not (equal b bb))
);or
(setq lst4 (append lst4 (list b)))
);if
(setq j 0);setq
(< (+ j 1) len)
);and
(setq c (nth j lst)
d (nth (+ j 1) lst)
flag (inters a b c d)
);setq (setq j (+ j 1));setq
);while (setq n (+ n 1));setq
);while
(if (not (equal b (last lst4)))
(setq lst4 (append lst4 (list b)));setq
);if
(if (not flag)
(setq flag lst4)
(setq flag nil)
);if
flag
);defun intersect_check ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
(defun truncate_2_view ( a b x y x2 y2 / int)
(if (and (< (car a) x)
(setq int (inters a b (list x y 0.0) (list x y2 0.0)))
);and
(setq a int)
(if (and (> (car a) x2)
(setq int (inters a b (list x2 y 0.0) (list x2 y2 0.0)))
);and
(setq a int)
);if else
);if
(if (and (< (cadr a) y)
(setq int (inters a b (list x y 0.0) (list x2 y 0.0)))
);and
(setq a int)
(if (and (> (cadr a) y2)
(setq int (inters a b (list x y2 0.0) (list x2 y2 0.0)))
);and
(setq a int)
);if else
);if a
);defun truncate_2_view
(princ "\n \"EXTRIM\" loaded.")
发表于 2004-11-9 19:59:00 | 显示全部楼层
程序不全,例如ac_bonus.lsp
 楼主| 发表于 2004-11-9 21:03:00 | 显示全部楼层
请alin再说清楚一点做法好吗,我还是不太清楚,我是从r14里拿出来的,希望能在2004里用,谢谢你了
发表于 2004-11-9 21:46:00 | 显示全部楼层
jack2913发表于2004-11-9 21:03:00请alin再说清楚一点做法好吗,我还是不太清楚,我是从r14里拿出来的,希望能在2004里用,谢谢你了
ALIN是叫你拿全面一点,不要拿一点不拿一点,少一点程序就断了。
发表于 2004-11-10 08:34:00 | 显示全部楼层
不建议这样做,如果没猜错的话,这应该是R14中bonus工具中的内容,相当于2000及以后版本的EXPRESS TOOLS,这是一套工具,你仅拿出其中的一部分,要求修改,这是不可以的,而且这个需要修改的并不会是LISP程序,LISP程序基本上是通用的,不用修改,但其中如果有ARX或别的东西,就不能通用了,是无法修改的...
2004建议直接使用EXPRESS TOOLS工具,应该有类似功能的命令
 楼主| 发表于 2004-11-11 00:17:00 | 显示全部楼层
meflying太感谢你了,我试试看
 楼主| 发表于 2004-11-12 01:26:00 | 显示全部楼层
meflying:
        在2004的EXPRESS TOOLS工具里没这功能,可以的话,帮我组织一下需要14里的那几个lisp,我再试试看,我敢决这lisp曼好用用的,谢谢你的协助!!!
发表于 2004-11-12 08:14:00 | 显示全部楼层
我5楼说的那么多话都白说了?
前一个原因我说了那么大一段,可你为什么就只看到后面那一段中的可能性?如果EXPRESS TOOLS里没有就没办法了(原因就在前一段说明了)......
我看你上面引用的这个程序,应该是超级剪切吧,,,EXPRESS TOOLS里面怎么可能没有?你仔细看了吗?
命令:EXTRIM
GMT+8, 2025-6-20 04:20 , Processed in 0.172553 second(s), 26 queries , Gzip On.
