帮助文件里面找
Return Values
A real value, if successful; otherwise nil.
The angtof and angtos functions are complementary: if you pass angtof a string created by angtos, angtof is guaranteed to return a valid value, and vice versa (assuming the unit values match).
Examples
Command: (angtof "45.0000")
0.785398
Command: (angtof "45.0000" 3)
1.0177
或
Examples
Command: (angtos 0.785398 0 4)
"45.0000"
Command: (angtos -0.785398 0 4)
"315.0000"
Command: (angtos -0.785398 4)
"S 45d E" |
