查看: 1773|回复: 2
[求助]如何遍历当前显示的图元(屏幕中)
发表于 2004-11-11 16:30:00 | 显示全部楼层 |阅读模式
如何遍历当前显示的图元(屏幕中),然后才可以分别编辑它的属性值。 (repeat (vla-get-count (model-space))
(setq acadobj (vla-item (model-space) *index*))
(if (vlax-write-enabled-p acadobj)
(vla-put-LinetypeScale acadobj newvalue)
(setq *index1* (+ *index1* 1))
(vlax-release-object acadobj)
(setq *index* (+ *index* 1))
) 上面的程序遍历了model-space中的所有图元,不是我想要的,请高手赐教。
发表于 2004-11-11 17:06:00 | 显示全部楼层
  1. ;;选取当前显示的图元
  2. (defun SEL (/ CTR SIZE SCREEN SCALE SIZE XSIZE RT LB SS)
  3.    (command "_.UCS" "V")
  4.    (setq CTR (getvar "VIEWCTR"))
  5.    (setq SIZE (getvar "VIEWSIZE"))
  6.    (setq SCREEN (getvar "SCREENSIZE"))
  7.    (setq SCALE (/ (car SCREEN) (cadr SCREEN)))
  8.    (setq XSIZE (* SCALE SIZE))
  9.    (setq RT (list (+ (car CTR) (/ XSIZE 2)) (+ (cadr CTR) (/ SIZE 2))))
  10.    (setq LB (list (- (car CTR) (/ XSIZE 2)) (- (cadr CTR) (/ SIZE 2))))
  11.    (setq SS (ssget "c" RT LB))
  12.    (command "_.UCS" "P")
  13.    SS
  14. );;遍歷选集
  15. (defun C:TT (/ SS N)
  16.    (if (setq N   0
  17.          SS (SEL)
  18.            )
  19.        (repeat (sslength SS)
  20.            (print (ssname SS N))
  21.            (setq N (1+ N))
  22.        )
  23.    )
  24.    (princ)
  25. )
 楼主| 发表于 2004-11-12 08:21:00 | 显示全部楼层
感谢斑竹
GMT+8, 2025-6-20 04:28 , Processed in 0.325850 second(s), 25 queries , Gzip On.
