查看: 2677|回复: 3
[求助][讨论]请教vl-directory-files
发表于 2004-11-24 22:41:00 | 显示全部楼层 |阅读模式
请教 (setq p(vl-directory-files "d:/"))
能不能弹出对话框的形式来选择文件夹呢???
发表于 2004-11-24 23:02:00 | 显示全部楼层
;;;Description:
;;;This module's function allow the user to browse for a specific folder (defun FolderBrowse (msg / obj folder path)
(vl-load-com)
(setq obj (vlax-create-object "Shell.Application"))
(setq folder (vlax-invoke-method obj 'BrowseForFolder 0 msg 1))
(if
(vl-catch-all-error-p
(setq path
(vl-catch-all-apply
'(lambda()
(vlax-get-property
(vlax-get-property
folder 'self
'path
nil
path
) 调用方法: (setq path (FolderBrowse "请选择一个文件夹")) (setq ls (vl-directory-files path))
 楼主| 发表于 2004-11-25 21:43:00 | 显示全部楼层
谢谢
我试一下
发表于 2019-4-9 15:06:30 | 显示全部楼层
留个脚印,方便以后查看
GMT+8, 2025-5-19 03:10 , Processed in 0.170948 second(s), 25 queries , Gzip On.
