查看: 2077|回复: 0
[求助]
发表于 2004-11-25 13:41:00 | 显示全部楼层 |阅读模式
UG NX 3.0运行出错,如何解决?
请哪位大侠指教:UG NX 3.0运行出错。在退出UG NX3.0后,再次进入时出错,如何解决?出错提示提示如下:
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600">        </v:shapetype>E:\install\UG NX3.0\An Error occured in RegEnumKey 234.jpg
<v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600">        <v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></v:path><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 209.25pt; HEIGHT: 86.25pt" type="#_x0000_t75"><v:imagedata o:title="An Error occured in RegEnumKey 234" src="file:///E:\CAD_TEMP\msohtml1\02\clip_image001.jpg"></v:imagedata></v:shape>
GMT+8, 2025-11-24 04:27 , Processed in 0.144810 second(s), 24 queries , Gzip On.
