查看: 2132|回复: 3
图形字典
发表于 2002-10-24 00:22:00 | 显示全部楼层 |阅读模式
请教老师一下,怎样透过 AutoLISP 取出图形字典 layerstatedictionary 里面的数据?谢谢!
发表于 2002-10-25 23:32:00 | 显示全部楼层
层的状态在tablesearch、tablenext函数试试。
发表于 2002-10-28 08:14:00 | 显示全部楼层
Try this example
(vl-load-com)
(defun GET-STATENAMES (/ COLLECTION NAMES)
  (if (not
        (vl-catch-all-error-p
          (setq        COLLECTION
                 (vl-catch-all-apply
                   (function (lambda ()
                               (vla-item (vla-getextensiondictionary
                                           (vla-get-layers
                                             (vla-get-activedocument
                                               (vlax-get-acad-object)
                                         "ACAD_LAYERSTATES"
    (vlax-for ITEM COLLECTION
      (print(entget (vlax-vla-object->ename item)))
      (setq NAMES (cons (strcase (vla-get-name ITEM)) NAMES))
发表于 2018-2-1 09:53:01 | 显示全部楼层
龙龙仔好强大
GMT+8, 2025-5-19 19:43 , Processed in 0.180385 second(s), 26 queries , Gzip On.
