查看: 2291|回复: 7
关于块引用移动出现的问题.......?????!!!!!!!
发表于 2004-12-2 15:40:00 | 显示全部楼层 |阅读模式
我用VB做CAD的编程,用块引用的MOVE方法移动块,然后用块引用的EXPLODE方法对块进行炸开,奇怪的是.有些块引用移动后能炸开,有些块引用移动后不能炸开.而移动前进行EXPLODE操作的话,都能炸开.
在CAD2000中不存在这个问题,但在CAD2004和2005中存在这种问题?
哪位大侠帮忙解决一下,看看到底是什么问题?
发表于 2004-12-2 15:57:00 | 显示全部楼层
不等比例的块引用VBA是不能炸开的,和移动没什么关系
 楼主| 发表于 2004-12-2 15:58:00 | 显示全部楼层
是整体缩放的,没用XSCALE或YSCALE做过缩放
发表于 2004-12-2 15:59:00 | 显示全部楼层
贴上你的代码看看
 楼主| 发表于 2004-12-2 16:07:00 | 显示全部楼层
<BR>        Call MoveLineBlockObject(BlockRef, ObjectLine, iDocIndex)<BR>        <BR>        BlockRef.Explode                                 <BR>        BlockRef.Delete
--------------------------------------------------------------------------<BR>ublic Sub MoveLineBlockObject(ByVal BlockRef As AcadBlockReference, ByVal ObjectLine As TCollection, ByVal iIndexBlock As Integer)<BR>         On Error Resume Next<BR>
         Plb = ObjectLine.BlockLeftBottom<BR>         Prt = ObjectLine.BlockRightTop<BR>
         ScaleRT = ObjectLine.ScaleRightTop<BR>         ScaleLB = ObjectLine.ScaleLeftBottom<BR>         <BR>         <BR>         If ObjectLine.ObjectType = m_SillObject Then<BR>                         If (ObjectLine.SpecialObjType &gt; 0) And (ObjectLine.SpecialObjType Mod 2 = 0) Then<BR>                                         pEndMove(0) = xBlockLeft + 800 - 200<BR>                         Else<BR>                                         pEndMove(0) = xBlockLeft + 400 - 200<BR>                         End If<BR>                         pEndMove(1) = xBlockTop + 400 + 250<BR>         Else<BR>                         pEndMove(0) = 1050<BR>                         pEndMove(1) = 1500 - ObjectLine.Height / 2 / dbScaleFactor<BR>         End If<BR>
         If (ObjectLine.ObjectType = m_NormalObject) And _<BR>                                 (ObjectLine.SpecialObjType = m_NormalObjRectangle) Then<BR>                         Dim xInsertPoint As Variant<BR>                         xInsertPoint = BlockRef.InsertionPoint<BR>                         MoveBasePoint(0) = xInsertPoint(0)<BR>                         MoveBasePoint(1) = xInsertPoint(1)<BR>                         <BR>                         pEndMove(0) = xBlockLeft + 400<BR>                         pEndMove(1) = xBlockTop + 0<BR>         ElseIf ObjectLine.ObjectType = m_NormalObject And ObjectLine.ColyModelLineObj.IsEspecialMdl Then<BR>                         MoveBasePoint(0) = (ScaleRT(0) + ScaleLB(0)) / 2<BR>                         MoveBasePoint(1) = ScaleLB(1) - 150<BR>         Else<BR>                         MoveBasePoint(0) = (ScaleRT(0) + ScaleLB(0)) / 2<BR>                         MoveBasePoint(1) = ScaleLB(1)<BR>         End If<BR>
         If ObjectLine.ObjectType = m_ChiNoObject Then<BR>                         MoveChiNoObj ObjectLine, MoveBasePoint<BR>         End If<BR>
                <BR>         ((((()))))<BR>
         BlockRef.Move MoveBasePoint, pEndMove<BR>         <BR>End Sub
我把EXPLODE放到引用的MOVE语句前就能炸开,位置在((((()))))处
其后就不行,对有些图形且是CAD2004,2005不行
 楼主| 发表于 2004-12-2 16:08:00 | 显示全部楼层
你有QQ或MSN么?我们在那上面聊方便些
发表于 2004-12-2 20:26:00 | 显示全部楼层
最好把你的图样(不能炸开的)贴上来
 楼主| 发表于 2004-12-3 11:19:00 | 显示全部楼层
发现新问题,不能炸开和图形的位置有关.
我把块引用的插入点设成原点(0,0,0),把图形放到距离原点的不同位置.我在代码中是把块引用移动到原点附近位置,然后炸开.当图形原始位置距离原点位置近时,不存在炸不开的问题.当图形距离原点足够远时,块引用移动后炸不开.
该现象只存在于CAD2004,2005中,CAD2000中不存在该问题.不知这是怎么回事????
GMT+8, 2025-10-11 04:32 , Processed in 0.199452 second(s), 23 queries , Gzip On.
