查看: 1663|回复: 2
acdbblockreference问题
发表于 2004-12-8 12:38:00 | 显示全部楼层 |阅读模式
用vb6.0,2004cad lib库; Dim acadapp As AcadApplication
Dim acaddoc As AcadDocument Set acadapp = GetObject(, "AutoCAD.application.16") acadapp.Documents.Open (filepath) '打开dwg文件
Set acaddoc = acadapp.ActiveDocument
acadapp.Visible = False For ind = 0 To acaddoc.ModelSpace.Count - 1'循环读取
Set ent = acaddoc.ModelSpace.Item(ind)
If ent.ObjectName = "AcDbBlockReference" Then
Set blockRefObj = ent
If UCase(blockRefObj.Name) = "TBZ10" or UCase(blockRefObj.Name) = "TBF00" And blockRefObj.HasAttributes = True Then
'取内容,略过 end if next 此遍历的方式太慢(要查询所有的object),如何能直接查询到块TBZ10(或它的blockreference),使速度加快。一个200k的dwg要一分多钟
发表于 2004-12-8 18:43:00 | 显示全部楼层
用选择集+过滤器
 楼主| 发表于 2004-12-8 18:55:00 | 显示全部楼层
怎么定义和使用,我还真不知道,能写代码吗
GMT+8, 2025-2-21 03:35 , Processed in 0.233680 second(s), 23 queries , Gzip On.
