查看: 2212|回复: 6
如何用vb快速查找到dwg里的已知名称的块blockreference
发表于 2004-12-8 18:52:00 | 显示全部楼层 |阅读模式
如何用vb快速查找到(或提取)dwg里的已知名称的块blockreference
发表于 2004-12-8 18:59:00 | 显示全部楼层
同一个主题不要分开发! 下面是一段测试 Private Sub Form_Load()
On Error Resume Next
Dim oApp As Object
Dim oDoc As Object
Set oApp = GetObject(, "AutoCad.Application")
Set oDoc = oApp.ActiveDocument
Dim ss As Object
oDoc.SelectionSets("Test").Delete
Set ss = oDoc.SelectionSets.Add("Test")
Dim ft(1) As Integer, fd(1)
ft(0) = 0: fd(0) = "Insert"
ft(1) = 2: fd(1) = "1"
ss.Select 5, ft, fd
MsgBox ss.Count
End Sub
 楼主| 发表于 2004-12-8 19:40:00 | 显示全部楼层
已知块名为fa或fb或fc,如何选择
发表于 2004-12-8 19:47:00 | 显示全部楼层
ft(1) = 2: fd(1) = "fa,fb,fc"
 楼主| 发表于 2004-12-8 20:07:00 | 显示全部楼层
Dim acadapp As AcadApplication
Dim acaddoc As AcadDocument
'初始化CAD
'On Error Resume Next
Set acadapp = GetObject(, "autocad.application.16")
If Err Then
Err.Clear
Set acadapp = CreateObject("autocad.application.16")
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
Dim filepath As String
filepath = "D:\Syq901\c0101-02.dwg"
acadapp.Documents.Open (filepath)
Set acaddoc = acadapp.ActiveDocument
acadapp.Visible = False
Dim ss As AcadSelectionSet
MsgBox (acaddoc.SelectionSets.Count)
'acaddoc.SelectionSets("test").Delete ---此处报错??????
Set ss = acaddoc.SelectionSets.Add("Test")
ft(0) = 0: fd(0) = "insert"
'ft(1) = 2: fd(1) = "fa,fb,fc"
ss.Select acSelectionSetAll, ft, fd
MsgBox ss.Count 结果还是ss.Count还是3000多,和没定义时一样多,选择了所有的,怎么回事?
发表于 2004-12-9 08:46:00 | 显示全部楼层
如果可以的话,贴一个样图上来看看
 楼主| 发表于 2004-12-9 08:49:00 | 显示全部楼层
换了一个文件,换了块名就可以了,这是为什么?我是cad2004查属性得到的块名。还是感谢班组的辛劳,十分感谢!!!
GMT+8, 2025-5-6 12:12 , Processed in 0.155865 second(s), 23 queries , Gzip On.
