查看: 2062|回复: 1
求教:解密问题
发表于 2004-12-19 19:20:00 | 显示全部楼层 |阅读模式
前一段时间从网上下了个加密程序,我想问一下,加密后的文件该如何才能解密。请各位赐教。谢谢。 源程序:
(alert
"\n不要在原图上运行该程序.
\n请在原图的备份上运行."
;;;(alert
;;; "\nLockup2.lsp - By John D. Chapman - Ainley and Associates Ltd.
;;; \n with thanks to Brian Debelius, Adam Conrath, Rick McElvain,
;;; \n Stig Madsen, Celie Dailey, Pat Starkey, Jim Fisher
;;; \n and the Autodesk User Group International."
;;;) (defun lockerror (msg)
(if (/= msg "Function cancelled")
(princ
(strcat "\nError: " msg " [" (itoa (getvar "ERRNO")) "]")
(command "UNDO" "End")
(Abort "\n加密被取消,停止加密!")
(setq *error* olderr)
) (defun Abort (msg)
(setvar "filedia" fdia)
(setvar "cmddia" cdia)
(setvar "cmdecho" cmd)
(alert msg)
;;Exit (defun getlayers ()
(setq lyr (tblnext "layer" t))
(setq laylist "")
(while lyr
(if (or (and (= (cdr (assoc 62 lyr)) 8)
(not (wcmatch (cdr (assoc 2 lyr)) "*|*"))
(and (= (cdr (assoc 62 lyr)) 9)
(and (= (cdr (assoc 62 lyr)) 251)
(and (= (cdr (assoc 62 lyr)) 252)
(and (= (cdr (assoc 62 lyr)) 253)
(and (= (cdr (assoc 62 lyr)) 254)
(and (= (cdr (assoc 62 lyr)) 255)
(if (equal laylist "")
(setq laylist (strcat laylist (cdr (assoc 2 lyr))))
(setq laylist (strcat laylist "," (cdr (assoc 2 lyr))))
(setq lyr (tblnext "layer"))
laylist
) (defun backblk (layoutName Mins)
(if layoutName
(cond
((= layoutName "14MS")
(setq blist (list '(-4 . "<NOT")
'(-4 . "<OR")
'(67 . 1)
'(0 . "SOLID")
'(2 . "SOLID")
'(-4 . "OR>")
'(-4 . "NOT>")
'(-4 . "<OR")
(cons 8 (getlayers))
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
((= layoutName "14PS")
(setq blist (list '(67 . 1)
'(-4 . "<NOT")
'(-4 . "<OR")
'(0 . "SOLID")
'(2 . "SOLID")
'(0 . "VIEWPORT")
'(-4 . "OR>")
'(-4 . "NOT>")
'(-4 . "<OR")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
(T
(setq blist (list (cons 410 layoutName)
'(-4 . "<NOT")
'(-4 . "<OR")
'(0 . "SOLID")
'(2 . "SOLID")
'(0 . "VIEWPORT")
'(-4 . "OR>")
'(-4 . "NOT>")
'(-4 . "<OR")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
'(-4 . "<OR")
'(0 . "SOLID")
'(2 . "SOLID")
'(0 . "VIEWPORT")
'(-4 . "OR>")
'(-4 . "NOT>")
'(-4 . "<OR")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
(setq ssetb (ssget "X" blist))
(setq viewsset (ssget "X" '((0 . "VIEWPORT"))))
(if viewsset
(setq n 0)
(repeat (sslength viewsset)
(if (setq clipent (assoc 340 (entget (ssname viewsset n))))
(ssdel (cdr clipent) ssetb)
(setq n (1+ n))
(if ssetb
(setq pt (list 0.0 0.0))
(entmake ;;write block header
(list '(0 . "BLOCK")
'(2 . "*anon")
'(70 . 1)
(cons '10 pt)
;;add entities in selection set to block
;;repeat for every entity in the selection set
(setq a 0)
(repeat (sslength ssetb)
(setq ent2 (entmake (entget (setq ent (ssname ssetb a)))))
(if (null ent2)
(princ (entget (setq ent (ssname ssetb a))))
;;if polyline or block reference with attributes,
;;walk down sub-entities until seqend is found
(if (assoc 66 (entget ent))
;;add sub-entities until seqend is found
(setq subent (entnext ent))
(while (/= (cdr (assoc 0 (entget subent))) "SEQEND")
(entmake (entget subent))
(setq subent (entnext subent))
) ;;add seqend sub-entity
(setq ent3 (entmake (entget subent)))
(if (null ent3)
(princ (entget subent))
;;delete original entity
(entdel ent)
(setq a (1+ a))
(c:spin "制作背景颜色图块..")
(setq nameb (entmake '((0 . "endblk"))))
;;write block end sub-entity
(princ "\n 插入...\n") ;; Insert block reference at insertion point
;; Note: Check the argument Mins for the method to insert the block
;; Note: Mins=T means minsert the block, and Mins=nil means insert it.
(if Mins
;;Minsert block reference at insertion point
(entmake
(list '(0 . "INSERT")
(CONS '100 "AcDbMInsertBlock")
(CONS '70 2)
(CONS '71 2)
(cons '2 nameb)
(cons '10 pt)
(entmake
(cons '2 nameb)
(cons '10 pt)
;;Insert block reference at insertion point
(setq bc (entlast))
(setq bac "back")
(command "_.draworder" bc "" (strcat "_" bac))
(setq ssetb nil)
(setq viewsset nil)
) (defun solidblk (layoutName Mins)
(if layoutName
(cond
(setq slist (list '(-4 . "<NOT") '(67 . 1)
'(-4 . "NOT>") '(-4 . "<OR")
'(0 . "SOLID") '(2 . "SOLID")
'(-4 . "OR>")
(setq slist (list '(67 . 1) '(-4 . "<OR") '(0 . "SOLID") '(2 . "SOLID")
'(-4 . "OR>"))
(T
(setq slist (list (cons 410 layoutName)
'(-4 . "<OR")
'(0 . "SOLID")
'(2 . "SOLID")
'(-4 . "OR>")
(setq slist (list '(-4 . "<OR")
'(0 . "SOLID")
'(2 . "SOLID")
'(-4 . "OR>")
(setq ssets (ssget "X" slist))
(if ssets
'(2 . "*anon")
'(70 . 1)
(cons '10 pt)
(setq a 0)
(repeat (sslength ssets)
(setq ent2 (entmake (entget (setq ent (ssname ssets a)))))
(if (null ent2)
(princ (entget (setq ent (ssname ssets a))))
(if (null ent3)
(entdel ent)
(setq a (1+ a))
(c:spin "制作对象图块..")
(setq names (entmake '((0 . "endblk"))))
(if Mins
(entmake
(CONS '70 2)
(CONS '71 2)
(cons '2 names)
(cons '10 pt)
(entmake
(cons '2 names)
(cons '10 pt)
(setq so (entlast))
(setq ba "back")
(command "_.draworder" so "" (strcat "_" ba))
(setq ssets nil)
) (defun anonBlock (layoutName Mins)
(if layoutName
(cond
(setq alist (list '(-4 . "<NOT")
'(-4 . "<OR")
'(67 . 1)
'(0 . "ACAD_PROXY_ENTITY")
'(0 . "AEC_*")
'(0 . "AECS_*")
'(0 . "RTEXT")
'(0 . "WIPEOUT")
;;'(8 . "LAYCFG")
(0 . "SOLID")
'(2 . "SOLID")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
'(-4 . "NOT>")
(setq alist (list '(67 . 1)
'(-4 . "<NOT")
'(-4 . "<OR")
'(0 . "VIEWPORT")
'(0 . "AEC_*")
'(0 . "AECS_*")
'(0 . "RTEXT")
'(0 . "WIPEOUT")
;;'(8 . "LAYCFG")
(0 . "SOLID")
'(2 . "SOLID")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
'(-4 . "NOT>")
(T
(setq alist (list (cons 410 layoutName)
'(-4 . "<NOT")
'(-4 . "<OR")
;;'(8 . "LAYCFG")
(0 . "VIEWPORT")
'(0 . "AECC_*")
'(0 . "AEC_*")
'(0 . "AECS_*")
'(0 . "RTEXT")
'(0 . "WIPEOUT")
'(0 . "SOLID")
'(2 . "SOLID")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
'(-4 . "NOT>")
'(-4 . "<OR")
;;'(8 . "LAYCFG")
(0 . "VIEWPORT")
'(0 . "AECC_*")
'(0 . "AEC_*")
'(0 . "AECS_*")
'(0 . "RTEXT")
'(0 . "WIPEOUT")
'(0 . "SOLID")
'(2 . "SOLID")
'(62 . 8)
'(62 . 9)
'(62 . 251)
'(62 . 252)
'(62 . 253)
'(62 . 254)
'(62 . 255)
'(-4 . "OR>")
'(-4 . "NOT>")
(setq sset (ssget "X" alist))
(if viewsset
(setq n 0)
(ssdel (cdr clipent) sset)
(setq n (1+ n))
(if sset
'(2 . "*anon")
'(70 . 1)
(cons '10 pt)
(setq a 0)
(repeat (sslength sset)
(setq ent2 (entmake (entget (setq ent (ssname sset a)))))
(if (null ent2)
(princ (entget (setq ent (ssname sset a))))
(if (null ent3)
(entdel ent)
(setq a (1+ a))
(c:spin "制作图块..")
(setq name (entmake '((0 . "endblk"))))
(princ "\n 插入图块..\n") ;; Insert block reference at insertion point
(if Mins
(entmake
(CONS '70 2)
(CONS '71 2)
(cons '2 name)
(cons '10 pt)
(entmake
(cons '2 name)
(cons '10 pt)
(setq sset nil)
(setq viewsset nil)
;; Note: This statement is just a debug string and can be deleted
(if layoutName
(princ (strcat "\n没有实体被锁 " layoutName))
) (defun Finish (vers)
(setvar "clayer" cla)
(setvar "tilemode" space)
(if (= vers 2)
(command "-layer" "state" "restore" "lockup" "" "")
(command "-layer" "lock" "*" "")
(setvar "proxyshow" 1)
(command "regen")
(cond
((= cont "Yes")
(alert
"\nPaper space only has been locked.
\nTo lock model space, run Lockup
\nagain and do NOT skip to paper space."
((= answer2 "Model")
(alert "\nAll selected entities have been locked.")
((= answer2 nil)
(setq cont nil
answer2 nil
(princ "\nLockup has completed. ")
) ;;; Note:
;;; Separate routine still for r14, because paper space is a whole different
;;; ballgame in later versions. It supplies the keyword "14PS" to be recognized
;;; by anonBlock in order to select all entities that have group code 67 = 1
(defun goLock14PS ()
(setvar "tilemode" 0)
(proxy)
(anonBlock "14PS" nil) ; make anon insert - on paper space
(backblk "14PS" nil) ; make anon insert - on paper space
(solidBlk "14PS" nil) ; make anon insert - on paper space
(anonBlock "14PS" T) ; make anon minsert - on paper space
(command "zoom" "extents")
(prompt "\n Paper Space has been locked.")
(Finish 0)
) (defun goLockPS (vers)
(if (= vers 0)
(goLock14PS)
(princ "\nType in Layout Name to make current: ")
(command "layout" "set" pause) ;type in whatever layout to set current
(while (> (getvar "cmdactive") 0) (command pause))
(proxy)
(anonBlock (getvar "CTAB") nil) ; make anon insert in named layout
(backblk (getvar "CTAB") nil) ; make anon insert in named layout
(solidblk (getvar "CTAB") nil) ; make anon insert in named layout
(anonBlock (getvar "CTAB") T) ; make anon minsert in named layout
(initget "Yes No")
(prompt
(strcat "\n Layout " (getvar "ctab") " has been locked.")
(setq answer
(getkword "\nAre there more layouts to lock? Y/<N>: ")
(cond
((or (null answer) (= answer "No"))
(Finish vers)
((= answer "Yes")
(goLockPS vers)
(T nil)
) (defun goLock (vers)
(setvar "tilemode" 1)
(if (= vers 2)
(command "-layer" "state" "save" "lockup" "" "" "")
(command "-layer" "thaw" "*" "on" "*" "unlock" "*" "")
(proxy)
(if (/= vers 0)
(anonBlock "Model" nil) ; make anon insert in model space
(backblk "Model" nil) ; make anon insert in model space
(solidblk "Model" nil) ; make anon insert in model space
(anonBlock "Model" T) ; make anon minsert in model space
(anonBlock "14MS" nil)
(backblk "14MS" nil)
(solidblk "14MS" nil)
(anonBlock "14MS" T)
(prompt "\n Model Space has been locked.")
(initget "Yes No")
(setq answer
(getkword "\nDo you want to lock Paper Space? Y/<N>: ")
(cond
((or (null answer) (= answer "No")) (Finish vers))
((= answer "Yes") (goLockPS vers))
(T nil)
) (defun states ()
(if (= vers 2)
(command "graphscr")
(goLockps vers)
) (defun continue ()
(initget "Yes No")
(setq cont (getkword
"\n模型空间不能加密,继续? Y/<N>: "
(cond ((= cont "Yes") (states))
((= cont "No") (skip))
((= cont nil) (skip))
) (defun skip ()
(initget "Skip Model")
(setq answer2
(getkword
"\n从模型空间还是跳转图纸空间开始? Skip/<Model>:"
(cond ((= answer2 "Skip") (continue))
((= answer2 "Model") (goLock vers))
((= answer2 nil) (goLock vers))
) (defun 14or2k (/ answer)
(initget "14 2000 2000i")
(setq answer
(getkword
"\n输入你的cad版本号 14/2000<2000i>: "
(cond
((= answer "14") (setq vers 0))
((= answer "2000") (setq vers 1))
((= answer "2000i") (setq vers 2))
((= answer nil) (setq vers 2))
(skip)
) (defun goexp ()
(command "_explode" (ssname sset CNT))
(setq CNT (1+ CNT))
(c:spin "Exploding..")
(alert (strcat "\n " (itoa CNT) " Entities Exploded."))
(setq sset nil)
) (defun xpproxy (/ xpl)
(alert
"\n Proxy Entities have been found.
If they are not exploded, they will
be omitted from the lockup process."
(initget "Yes No")
(setq xpl (getkword "\nExplode Proxy Entities? Y/<N>: "))
(if (or (= xpl "No") (= xpl nil))
(if (= xpl "Yes")
(goexp)
) (defun goerase ()
(repeat (sslength wsset)
(entdel (ssname wsset WCNT))
(setq WCNT (1+ WCNT))
(c:spin "Erasing..")
(alert (strcat "\n " (itoa WCNT) " Wipeouts Erased."))
(setq wsset nil)
) (defun goaskerase (/ del)
(alert
"\n Wipeouts have been found."
(initget "Yes No")
(setq del (getkword "\nErase Wipeouts? Y/<N>: "))
(if (or (= del "No") (= del nil))
(if (= del "Yes")
(goerase)
) (defun gowipeout (/ where wlist)
(setq where (getvar "tilemode"))
(setq cs 67)
(if (= where 0)
(setq sp 1)
(if (= where 1)
(setq sp 0)
(setq wlist (list (cons cs sp)
'(0 . "wipeout")
(setq WCNT 0)
(setq wsset (ssget "x" wlist))
(if (= wsset nil)
(if (not (= wsset nil))
(goaskerase)
) (defun proxy (/ where plist)
(if (= where 0)
(setq plist '((-4 . "<NOT")
(67 . 0)
(-4 . "NOT>")
(-4 . "<OR")
(0 . "AECC_*")
(0 . "AEC_*")
(0 . "AECS_*")
(0 . "RTEXT")
(-4 . "OR>")
(if (= where 1)
(67 . 1)
(-4 . "NOT>")
(-4 . "<OR")
(0 . "AECC_*")
(0 . "AEC_*")
(0 . "AECS_*")
(0 . "RTEXT")
(-4 . "OR>")
(setq CNT 0)
(setq sset (ssget "x" plist))
(if (= sset nil)
(if (not (= sset nil))
(xpproxy)
(gowipeout)
) (defun c:undolock ()
;;Undo and Reset variables
(setvar "cmdecho" 0)
(princ "\n请等待解密.")
(command "undo" "end")
(command "undo" "back")
(setvar "cmdecho" 1)
(setvar "filedia" 1)
(setvar "cmddia" 1)
(setvar "clayer" "2")
(princ "\n加密已经被取消.")
) (defun c:look (/ alist CNT sset)
(setq alist '((-4 . "<OR")
(0 . "AECC_*")
(0 . "AEC_*")
(0 . "AECS_*")
(0 . "RTEXT")
(0 . "WIPEOUT")
(-4 . "OR>")
(setq CNT 0)
(if alist
(if sset
(setq CNT (1+ CNT))
(if (= CNT 1)
(alert (strcat "\n " (itoa CNT) " Entity found."))
(if (> CNT 1)
(alert (strcat "\n " (itoa CNT) " Entities found."))
(if (= sset nil)
(alert "\nNo Entities were found.")
) (defun c:spin (wh)
(prompt (strcat "\r "
wh
(cond ((= sp "|") (setq sp "/"))
((= sp "/") (setq sp "-"))
((= sp "-") (setq sp "\\"))
(T (setq sp "|"))
) (defun Cockup (/ start answer)
(setq fdia (getvar "filedia")
cdia (getvar "cmddia")
cmd (getvar "cmdecho")
cla (getvar "clayer")
space (getvar "tilemode")
olderr *error*
*error* lockerror
cont nil
answer2 nil
(command "UNDO" "Begin")
(setvar "filedia" 0)
(setvar "cmddia" 0)
(command "undo" "mark")
(command "-layer" "make" "LOCKUP" "")
(command "color" "bylayer")
(setvar "proxyshow" 0)
(command "regen")
(initget "Yes No")
(setq answer
(getkword
"\n程序将要加密图纸。 Y/<N>: "
(cond
((or (= answer "No") (null answer))
(Alert "加密失败!")
((= answer "Yes") (14or2k))
(princ "\nLOCKUP 加载成功.")
(princ "\n输入 LOCKUP 运行程序.")
发表于 2022-9-27 18:59:19 | 显示全部楼层
楼主好走走看看转一转
GMT+8, 2026-1-16 04:19 , Processed in 0.173656 second(s), 25 queries , Gzip On.
