查看: 1799|回复: 3
如何得到矩形GROUP的四个端点?
发表于 2004-12-23 09:25:00 | 显示全部楼层 |阅读模式
我图中有个矩形的GROUP实体,如何通过程序得到这个GROUP的四个端点坐标?
 楼主| 发表于 2004-12-23 09:53:00 | 显示全部楼层
上传一个例图,望高手指教
发表于 2004-12-23 10:45:00 | 显示全部楼层
写了一点,没时间写了,你自己再改改吧. Sub test()
Dim group(0 To 3) As AcadLine
Dim point As Variant
Dim sset As AcadSelectionSet
Dim entry As AcadEntity
Dim i As Integer
ThisDrawing.SendCommand "prompt" & "请选择"
point = ThisDrawing.Utility.GetPoint()
For i = 0 To ThisDrawing.SelectionSets.Count - 1
If ThisDrawing.SelectionSets.Item(i).Name = "ss1" Then ThisDrawing.SelectionSets.Item("ss1").Delete
Next i
Set sset = ThisDrawing.SelectionSets.Add("ss1")
sset.SelectAtPoint point
Set group(0) = sset.Item(0)
Set group(1) = sset.Item(1)
Set group(2) = sset.Item(2)
Set group(3) = sset.Item(3)
Dim pos(0 To 7) As Variant
pos(0) = group(0).StartPoint
pos(1) = group(1).StartPoint
pos(2) = group(2).StartPoint
pos(3) = group(3).StartPoint
MsgBox pos(0)(0) & " " & pos(0)(1) & " " & pos(0)(2) & vbCrLf & pos(1)(0) & " " & pos(1)(1) & " " & pos(1)(2) & vbCrLf & pos(2)(0) & " " & pos(2)(1) & " " & pos(2)(2) & vbCrLf & pos(3)(0) & " " & pos(3)(1) & " " & pos(3)(2)
End Sub
 楼主| 发表于 2004-12-23 11:34:00 | 显示全部楼层
谢谢老大。非常感谢,我改改
GMT+8, 2025-9-9 04:31 , Processed in 0.181477 second(s), 24 queries , Gzip On.
