查看: 3389|回复: 8
[LISP]如何获得当前图形的比例尺
发表于 2004-12-25 10:08:00 | 显示全部楼层 |阅读模式
请问各位大侠 如何获得当前图形的比例尺??
发表于 2004-12-25 10:14:00 | 显示全部楼层
说得明白一点,在什么条件求比例!
 楼主| 发表于 2004-12-25 10:25:00 | 显示全部楼层
在模型空间要求绘图比例!
发表于 2004-12-26 20:02:00 | 显示全部楼层
这应该是无法获得的,我们绘图时是零件图画好后就缩小放到标准图框里,然后在图框中填入缩小的比例,标注时在标注样式中放大相应的比例就行了.
发表于 2004-12-28 21:16:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-12-28 22:08:00 | 显示全部楼层
能看明白这个程序,你就是图纸空间中的视口与模型空间是什么关系了,你的比例就求出来了! (prompt "\nDETAIL - CADENCE 1999")
;; CADENCE January 1999 - Bill Kramer
;; Detail enlargement macro set.
;; Listing 1: The Main Program
(defun C:DETAIL ( / P1 EN EL PTS SS1)
(cond
;;Set up AutoCAD system variables
((DETAIL_0)
(prompt "\nError in DETAIL_0"))
;;Operator input of detail center
;;and radius.
((DETAIL_1) ;;set up EL, P1, RD
(prompt "\nError in DETAIL_1"))
;;Operator input of detail graphic location
;;and scale for detail display.
;;Copy detail area, remove non-detail objects
;;like dimensions and text, and scale as
;;input by the operator.
((DETAIL_2) ;;set up P2, SS1, EN, ENT, SCL
(prompt "\nError in DETAIL_2"))
;;Do the trimming of the detail display.
((DETAIL_3)
(prompt "\nError in DETAIL_3"))
;;Create the text tag and draw connecting
;;line between original area and detail
;;area.
((DETAIL_4) ;;Output text tag
(prompt "\nError in DETAIL_4"))
('T (prompt "\nDetail finished okay."))
;;Reset system variables
(mapcar '(lambda (X)
(setvar (car X) (cadr X))) SYSVAR_LIST)
(prompt "\nUse TRIM to complete if needed.")
;; Listing 2: Set up system variables
(defun DETAIL_0 ()
(setq SYSVAR_LIST (mapcar '(lambda (X)
(list X (getvar X)))
'("CMDECHO"
"OSMODE"
"ORTHOMODE"
"HIGHLIGHT"
(setvar "CMDECHO" 0)
(setvar "OSMODE" 0)
(setvar "ORTHOMODE" 0)
(setvar "HIGHLIGHT" 0)
(if (zerop (getvar "WORLDUCS"))
(command "_UCS" "_W"))
nil
;; Listing 3: Establish area to detail
(defun DETAIL_1 ()
(setq P1 (getpoint "\nDetail center: "))
(if P1 (progn
(prompt "\nShow detail area: ")
(command "_CIRCLE" P1 pause)
(setq EN (entlast)
EL (entget EN)
RD (if (= (cdr (assoc 0 EL)) "CIRCLE")
(cdr (assoc 40 (entget EN)))
nil)
(if RD (progn
(entdel EN)
(command "_POLYGON" 15 P1 "I" RD)
(setq EN (entlast)
EL (entget EN)
nil ;return nil
1 ;return error level 1.
) ;;level 1 is RD not set
2 ;;return error level 2.
) ;level 2 is P1 not set
;; Listing 4: Copy objects to new location
(defun DETAIL_2 ()
(while (setq TMP (assoc 10 EL))
(setq EL (cdr (member TMP EL))
PTS (cons (cdr TMP) PTS)
(entdel EN)
(setq SS1 (ssget "CP" PTS)
P2 (getpoint P1 "\nPut detail at: ")
CNT (if SS1 (sslength SS1) 0)
(if P2 (progn
(repeat CNT
(if (member
(cdr (assoc 0
(entget
(ssname
SS1
(setq CNT (1- CNT))))))
'("TEXT" "DIMENSION"
"MTEXT" "INSERT"
(ssdel (ssname SS1 CNT) SS1)
(command "_CIRCLE" P1 RD
"_CIRCLE" P2 RD)
(setq EN (entlast)
ENT EN)
(command "_COPY" SS1 "" P1 P2)
(setq SS1 (ssadd EN))
(while (setq ENT (entnext ENT))
(ssadd ENT SS1)
(setq SCL (getreal "\nScale factor (2): "))
(if (null SCL) (setq SCL 2.0))
(if (/= SCL 1.0)
(command "_SCALE" SS1 "" P2 SCL)
nil ;;return nil result, all okay.
1 ;;return error code 1
) ;;error code, P2 not input.
;; Listing 5: Trim the objects copied
(defun DETAIL_3 ()
(setq TTT 0) ;;change counter
(while (setq ENT (ssname SS1 0))
(ssdel ENT SS1)
(if (not (equal ENT EN)) (progn
(setq EL (entget ENT)
PT (DETAIL_3A EL)
(if (and PT
(> (distance P2 PT)
(+ 0.2 (* RD SCL))))
(setq TTT (1+ TTT))
(command "_TRIM" EN ""
(list ENT PT) "")
(DETAIL_3B) ;;loop again check
nil
;; Listing 6: Find point on object for trim
(defun DETAIL_3A (EL / TY)
(setq TY (cdr (assoc 0 EL)))
(cond
((= TY "LINE")
(if (> (distance (cdr (assoc 10 EL)) P2)
(distance (cdr (assoc 11 EL)) P2))
(cdr (assoc 10 EL))
(cdr (assoc 11 EL))
((= TY "ARC")
(setq PC (cdr (assoc 10 EL))
PR (cdr (assoc 40 EL))
PA (cdr (assoc 50 EL))
PB (cdr (assoc 51 EL))
(if (> (distance (polar PC PA PR) P2)
(distance (polar PC PB PR) P2))
(polar PC PA PR)
(polar PC PB PR)
((= TY "CIRCLE")
(cond
((> (distance P2
(polar PC 0.0 PR))
(* RD SCL))
(polar PC 0.0 PR))
((> (distance P2
(polar PC PI PR))
(* RD SCL))
(polar PC PI PR))
((> (distance P2
(polar PC (* 0.5 PI) PR))
(* RD SCL))
(t (polar PC (* 1.5 PI) PR))
((= TY "LWPOLYLINE")
(setq PR nil)
(while (and (null PR)
(setq PA (assoc 10 EL)))
(setq EL (cdr (member PA EL))
PA (cdr PA)
(if (> (distance P2 PA) (* RD SCL))
(setq PR PA)))
((= TY "SPLINE")
(setq PR nil)
(setq PA (assoc 11 EL))
PA (cdr PA))
(setq PR PA)))
((= TY "POLYLINE")
(setq EL (entget
(entnext
(cdr (assoc -1 EL))))
PR nil)
"VERTEX"))
(setq PA (cdr (assoc 10 EL))
EL (entget
(entnext
(* RD SCL))
(setq PR PA)
;;add more objects here
) ;;end COND for PT assignment
;; Listing 7: Loop control options for user
(defun DETAIL_3B ()
(if (= (sslength SS1) 0)
(if (> TTT 0) (progn
(initget 0 "Yes No")
(setq TTT (getkword (strcat
"\nChanged "
(itoa TTT)
" objects, Loop again? <Yes>")))
(if (or (null TTT) (= TTT "Yes"))
ENT EN)
(ssadd ENT SS1)
(setq TTT 0)
;; Listing 8: Finishing touches
(defun DETAIL_4 ()
(command "_TEXT"
"_Justify" "_Center"
(polar P2
(* PI 1.5)
(+ (* SCL RD)
(* 2.5
(getvar "TEXTSIZE"))))
(if (zerop (cdr (assoc 40
(tblsearch
"STYLE"
(getvar "TEXTSTYLE")))))
(command "") ;;text height output option
(command 0 ;;finish the TEXT command sequence.
(strcat "Enlarged "
(rtos SCL 2
(Best_Prec SCL 0 4))
"x")
;; Construct line between detail circles.
(command "_LINE" (polar P1 (angle P1 P2) RD)
(polar P2 (angle P2 P1) (* RD SCL))
nil
;; Listing 9: Utility Routine from toolbox
;; Best_Prec - Given a number (NUM) and the
;; minimum and maximum precision, this function
;; returns the precision in the range that will
;; best fit the number.
(defun Best_Prec (Num Mn Mx)
(while (and (<= Mn Mx)
(/= Num (atof (rtos Num 2 Mn))))
(setq Mn (1+ Mn))
Mn
;; How can I get the coordinate relationship
;; between paper space and model space in a
;; specific viewport (while tilemode = 0)?
;; 这是一个非常有用的例子,看出它们的关系了吗??
;; 我以前也为找出它们的关系花了不少时间
(defun C:TEST (/ A W WDXF EA EN XP W10 W40 W41 W69 VCTRX VCTRY LPT RPT)
(setvar "tilemode" 0)
(command "_.PSPACE")
(while (not A)
(setq A (ssget ":s" '((0 . "VIEWPORT"))))
(setq W (ssname A 0))
(setq WDXF (entget W))
(setq EA (assoc -3 (entget W '("ACAD")))
EN (reverse (cdr (reverse (cdr (cddadr EA)))))
(setq XP (/ (cdr (assoc 41 WDXF)) (cdr (nth 4 EN))))
(setq W10 (cdr (assoc 10 WDXF)))
(setq W40 (/ (cdr (assoc 40 WDXF)) XP))
(setq W41 (/ (cdr (assoc 41 WDXF)) XP))
(setq W69 (cdr (assoc 69 WDXF)))
(command "_.MSPACE")
(command "_.cvport" W69)
(command "_.ucs" "v")
(setq VCTRX (car (getvar "viewctr")))
(setq VCTRY (cadr (getvar "viewctr")))
(setq LPT (list (- VCTRX (/ W40 2.0)) (- VCTRY (/ W41 2.0))))
(setq RPT (list (+ VCTRX (/ W40 2.0)) (+ VCTRY (/ W41 2.0))))
(command "_.rectang" LPT RPT)
发表于 2004-12-29 21:52:00 | 显示全部楼层
如果我没有记错,看看dimtxt这个系统变量,好象就是当前图形的比例。
发表于 2004-12-31 18:25:00 | 显示全部楼层
dimtxt 是文字高度。dimscale 是比例。
 楼主| 发表于 2005-1-1 23:15:00 | 显示全部楼层
谢谢各位
太感谢拉
GMT+8, 2025-2-19 06:38 , Processed in 0.187334 second(s), 25 queries , Gzip On.
