查看: 2184|回复: 5
請教
发表于 2002-10-30 22:31:00 | 显示全部楼层 |阅读模式
(defun CCO (/ SS CNT LAY)
(setq SS (ssget))
(setq CNT (sslength SS))
(princ (strcat "\n" (itoa CNT) " 找到."))
(while (/= lay "")
(setq LAY (getstring "\n請輸入層名 / <ENTER結束命令>: "))
(if (and (/= "" LAY) (tblsearch "LAYER" LAY))
(setq ss1 (ssget "p"))
(command "_.copy" SS1 "" "0,0" "0,0")
(command "_.change" SS1 "" "_p" "_la" LAY "")
        (prompt
          (strcat "\n" (itoa (sslength SS)) " 物件拷貝到圖層 " LAY)
      (if (and (/= "" LAY) (= NIL (tblsearch "LAYER" LAY)))
(alert (strcat "沒有 \"" LAY "\" 這個圖層!!!"))
;這個程序現在有一個缺點就是不能復制到已關閉的圖層(第一個可以,接著就不行了),還望高手多多指教
发表于 2002-11-1 07:31:00 | 显示全部楼层
I Just simply load your routines in my AutoCAD, and
it works well. I can copy an object to a locked layer as many times as I want.
发表于 2002-10-31 06:46:00 | 显示全部楼层
It can, in AutoCAD 2002
 楼主| 发表于 2002-10-31 21:30:00 | 显示全部楼层
能不能說祥細點阿
 楼主| 发表于 2002-11-3 18:22:00 | 显示全部楼层
能不能給點程序阿
发表于 2002-11-10 21:20:00 | 显示全部楼层
怎么没人回答我呢??????
GMT+8, 2025-4-12 13:56 , Processed in 0.184584 second(s), 27 queries , Gzip On.
