查看: 2515|回复: 0
[求助]请教高手setUserInputControls
发表于 2004-12-28 13:29:00 | 显示全部楼层 |阅读模式
帮助里面是这样写的: Use the following function to change the default user input controls: void setUserInputControls(AcEdJig::UserInputControls uic);
The user input controls put limitations on the drag sequence or the type of acceptable return value (for example, by not allowing negative responses, by not allowing a zero response, or by restricting the input value to a 2D coordinate). They also specify how various user actions affect the drag sequence. For example, kAcceptMouseUpAsPoint specifies that releasing the mouse button indicates the input value 主要想问:For example, kAcceptMouseUpAsPoint specifies that releasing the mouse button indicates the input value 这个是通过什么实现的?有通过系统变量吗?其他如Lisp或VBA能否实现?
GMT+8, 2025-10-15 04:12 , Processed in 0.213444 second(s), 23 queries , Gzip On.
