查看: 1295|回复: 2
为什么这个程序在2002中不能正常运行呢??
发表于 2004-12-29 11:51:00 | 显示全部楼层 |阅读模式
Public Sub aaawe()
Dim obj As AcadBlockReference
Dim str As String
Dim point(2) As Double
point(0) = 100: point(1) = 100: point(2) = 0
str = "c:\wjct\tl\dxs.dwg"
Set obj = ThisDrawing.ModelSpace.InsertBlock(point, str, 1#, 1#, 1#, 1#)
End Sub
总是提示我插入块作用于Iacadmodelspace*对象错误
发表于 2004-12-29 12:39:00 | 显示全部楼层
Set obj = ThisDrawing.ModelSpace.InsertBlock(point, str, 1#, 1#, 1#, 1)
 楼主| 发表于 2004-12-29 13:09:00 | 显示全部楼层
谢过2楼的兄弟
GMT+8, 2025-5-31 21:53 , Processed in 0.139420 second(s), 23 queries , Gzip On.
