查看: 1722|回复: 2
如何用vba设置打印机?
发表于 2004-12-30 12:18:00 | 显示全部楼层 |阅读模式
如何用vba设置打印式样、纸张大小、打印范围(用窗口)等?
发表于 2004-12-30 13:09:00 | 显示全部楼层
'========如果有打印任务=============
DoEvents
If Check4.Value = 1 Then
cadmessage.Label7.Caption = "正在设置打印机。。。。。。"
'6,设置打印设备
dwgfile.ActiveLayout.ConfigName = Combo2.Text
'7,设置打印模式
dwgfile.ActiveLayout.StyleSheet = Combo3.Text
'1,图纸尺寸与单位
dwgfile.ActiveLayout.CanonicalMediaName = Combo4.Text
dwgfile.ActiveLayout.PaperUnits = acMillimeters
'2,调整打印原点
Dim BASEPIONT As Variant
BASEPIONT = dwgfile.ActiveLayout.PlotOrigin
dwgfile.ActiveLayout.CenterPlot = True
'3,设置打印区域
dwgfile.ActiveLayout.PlotType = acExtents
'4,设置打印比例
dwgfile.ActiveLayout.StandardScale = acScaleToFit
'5,设置线宽比例
dwgfile.ActiveLayout.ScaleLineweights = False '建议不要设置线宽缩放
dwgfile.ActiveLayout.PlotRotation = ac90degrees
'打印机已选择
cadmessage.Label7.Caption = "正在打印。。。。。。"
dwgfile.Plot.PlotToDevice
'开始打印
End If
 楼主| 发表于 2004-12-30 13:33:00 | 显示全部楼层
我想知道如何设置打印范围(窗口选择)?
GMT+8, 2025-2-22 17:37 , Processed in 0.229794 second(s), 24 queries , Gzip On.
