查看: 3246|回复: 5
[求助]如何在LISP中求面积?
发表于 2005-1-1 12:39:00 | 显示全部楼层 |阅读模式
如何在LISP中实现对一封闭的多义线或圆实现求面积呀?函数怎么写呀?
发表于 2005-1-1 21:40:00 | 显示全部楼层
xstlf您好!在元旦您还上网问问题呀?下面是两个小程序:
  1. ;选封闭图形内一点计算
  2. (defun c:area2 ()
  3. (setvar "cmdecho" 0)
  4. (command "_.undo" "be")
  5. (setq pt (getpoint "\n请点取要标注的范围内一点:"))
  6. (command "-boundary" pt "")
  7. (command "area" "o" (entlast))
  8. (command "erase" (entlast) "")
  9. (setq area (getvar "area"))
  10. (command "text" "j" "c" pt "5" "0" (rtos area 2 3))
  11. (princ "\n该范围的面积为A=")
  12. (princ (rtos (/ area 1000000) 2 4))
  13. (princ "M(")
  14. (princ (rtos area 2 3))
  15. (princ "mm)。")
  16. (command "_.undo" "e")
  17. (setvar "cmdecho" 1)
  18. (princ)
  19. )
  1. ;选择封闭曲线计算
  2. (defun c:area3 ()
  5. (princ "\n请选择封闭曲线 :")
  6. (setq  ss (ssget '((0 . "LWPOLYLINE,CIRCLE"))))
  7. (setq sl (sslength ss) i 0)
  8. (repeat sl
  9.   (setq ent (ssname ss i) i (1+ i))
  10.   (command "area" "o" ent)
  11.   (setq area (getvar "area"))
  12.   (princ "\n该范围的面积为A=")
  13.   (princ (rtos (/ area 1000000) 2 4))
  14.   (princ "M(")
  15.   (princ (rtos area 2 3))
  16.   (princ "mm)。")
  17. )
  18. (command "_.undo" "e")
  19. (setvar "cmdecho" 1)
  20. (princ)
  21. )
 楼主| 发表于 2005-1-2 14:12:00 | 显示全部楼层
谢谢,用,getvar函数还有此妙用呀,呵呵。
 楼主| 发表于 2005-1-9 17:37:00 | 显示全部楼层
现在才真正搞明白,原来area既是命令又是系统变量呀,呵呵。
发表于 2005-8-5 18:29:00 | 显示全部楼层
如果一个端点一个端点地选呢?我怎么实现不了?没有等到选,就直接要求输入输出数据的放置点了……
发表于 2005-8-5 21:15:00 | 显示全部楼层
可以先生成面域呀,再AREA OBJECT 点击即可呀
GMT+8, 2025-4-28 16:19 , Processed in 0.179199 second(s), 32 queries , Gzip On.
