查看: 38635|回复: 78
vb编程68例
发表于 2005-1-6 11:36:00 | 显示全部楼层 |阅读模式
1. 如何消除textbox中按下回车时的beep声?
Private Sub Text1_KeyPress(KeyAscii As Integer)
If KeyAscii = 13 Then
KeyAscii = 0
End If
End Sub 2.Textbox获得焦点时自动选中。
Private Sub Text1_GotFocus()
Text1.SelStart = 0
Text1.SelLength = Len(Text1.Text)
End Sub 3.屏蔽textbox控件自身的右键菜单,并显示自己的菜单。
方法一:
Private Sub Text1_MouseDown(Button As Integer, Shift As Integer, X As Single, Y _
As Single)
If Button = 2 Then
Text1.Enabled = False
Text1.Enabled = True
PopupMenu mymenu
End If
End Sub 方法二:回调函数
module:
Option Explicit
Public OldWindowProc As Long ' 保存默认的窗口函数的地址
Public Const WM_CONTEXTMENU = &H7B ' 当右击文本框时,产生这条消息
Public Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hWnd _
As Long, ByVal nIndex As Long) As Long
Public Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hWnd _ As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal _ lpPrevWndFunc As Long, ByVal hWnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Public Function SubClass_WndMessage(ByVal hWnd As Long, ByVal Msg As Long, ByVal wp _
As Long, ByVal lp As Long) As Long
' 如果消息不是WM_CONTEXTMENU,就调用默认的窗口函数处理
If Msg <> WM_CONTEXTMENU Then
SubClass_WndMessage = CallWindowProc(OldWindowProc, hWnd, Msg, wp, lp)
Exit Function
End If
SubClass_WndMessage = True
End Function
窗体中:
Private Const GWL_WNDPROC = (-4)
As Single)
If Button = 1 Then Exit Sub
OldWindowProc = GetWindowLong(Text1.hWnd, GWL_WNDPROC) ' 取得窗口函数的地址
' 用SubClass_WndMessage代替窗口函数处理消息
Call SetWindowLong(Text1.hWnd, GWL_WNDPROC, AddressOf SubClass_WndMessage)
End Sub
Private Sub Text1_MouseUp(Button As Integer, Shift As Integer, X As Single, Y As Single)
' 恢复窗口的默认函数
Call SetWindowLong(Text1.hWnd, GWL_WNDPROC, OldWindowProc)
PopupMenu mymenu
End Sub
参与人数 1威望 +1 金钱 +10 贡献 +5 激情 +5 收起 理由
雪山飞狐_lzh + 1 + 10 + 5 + 5 【精华】好程序
 楼主| 发表于 2005-1-6 11:36:00 | 显示全部楼层
4. 设置TEXTBOX为只读属性
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd _
As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd _ As Long, ByVal nIndex As Long) As Long
Private Const GWL_STYLE = (-16)
Private Const EM_SETREADONLY = &HCF
Private Sub Command1_Click()
Dim l As Long
If (GetWindowLong(Text1.hwnd, GWL_STYLE) And &H800) Then
Text1.Text = "This is a read/write text box." '文本窗口是只读窗口,设置为可读写窗口
l = SendMessage(Text1.hwnd, EM_SETREADONLY, False, vbNull)
Text1.BackColor = RGB(255, 255, 255) '将背景设置为白色
Command1.Caption = "Read&Write"
Else
Text1.Text = "This is a readonly text box." '文本窗口是可读写窗口,设置为只读窗口
l = SendMessage(Text1.hwnd, EM_SETREADONLY, True, vbNull)
Text1.BackColor = vbInactiveBorder '将背景设置为灰色
Command1.Caption = "&ReadOnly"
End If
End Sub 5. 利用API函数MessageBox代替MSGBOX函数可以使得Timer控件正常工作 Private Declare Function MessageBox Lib "user32" Alias "MessageBoxA" (ByVal hwnd As _ Long, ByVal lpText As String, ByVal lpCaption As String, ByVal wType As Long) As Long
MsgBox "时钟变的无效了"
End Sub
Private Sub Command2_Click()
MessageBox Me.hwnd, "时钟正常运行", "hehe", 0
End Sub
Private Sub Timer1_Timer()
Static i As Integer
i = i + 1
Text1.Text = i
End Sub Private Declare Function SetWindowPos Lib "user32" (ByVal hwnd As Long, ByVal _ hWndInsertAfter As Long, ByVal X As Long, ByVal Y As Long, ByVal Cx As Long, ByVal Cy _
As Long, ByVal wFlags As Long) As Long
Public Sub SetOnTop(ByVal IsOnTop As Integer)
Dim rtn As Long
If IsOnTop = 1 Then
rtn = SetWindowPos(Form1.hwnd, -1, 0, 0, 0, 0, 3)
Else
rtn = SetWindowPos(Form1.hwnd, -2, 0, 0, 0, 0, 3)
End If
End Sub
SetOnTop 1 '将窗口置于最上面
End Sub
SetOnTop 0
End Sub 7.只容许运行一个程序实例(利用互斥体) 选择启动对象为sub main()
module:
Public Declare Function CreateMutex Lib "kernel32" Alias "CreateMutexA" _ (lpMutexAttributes As SECURITY_ATTRIBUTES, ByVal bInitialOwner As Long, ByVal lpName _
As String) As Long
Public Type SECURITY_ATTRIBUTES
nLength As Long
lpSecurityDescriptor As Long
bInheritHandle As Long
End Type
Public Const ERROR_ALREADY_EXISTS = 183&
Private Sub Main()
Dim sa As SECURITY_ATTRIBUTES
sa.bInheritHandle = 1
sa.lpSecurityDescriptor = 0
sa.nLength = Len(sa)
Debug.Print CreateMutex(sa, 1, App.Title) '这一行可千万不能删除啊
Debug.Print Err.LastDllError
If (Err.LastDllError = ERROR_ALREADY_EXISTS) Then
MsgBox "More than one instance"
Else
Form1.Show
End If
End Sub 8.窗体标题栏闪烁
Option Explicit
Private Declare Function FlashWindow Lib "user32" (ByVal hwnd As Long, ByVal bInvert _
As Long) As Long
Private Sub tmrFlash_Timer()
Static mFlash As Boolean
FlashWindow hwnd, Not mFlash
End Sub
8. 拷屏 方法一:利用模拟键盘
Private Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal bScan As Byte, _ ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Const theScreen = 1
Const theForm = 0
Call keybd_event(vbKeySnapshot, theForm, 0, 0) '若theForm改成theScreen则Copy整个Screen
DoEvents
Picture1.Picture = Clipboard.GetData(vbCFBitmap)
End Sub
 楼主| 发表于 2005-1-6 11:37:00 | 显示全部楼层
9. 为程序注册热键 方法一:修改注册表
Private Declare Function RegisterHotKey Lib "user32" (ByVal hWnd As Long, ByVal id _
As Long, ByVal fsModifiers As Long, ByVal vk As Long) As Long
Private Declare Function UnregisterHotKey Lib "user32" (ByVal hWnd As Long, ByVal id _
As Long) As Long
Private Declare Function PeekMessage Lib "user32" Alias "PeekMessageA" (lpMsg As Msg, _ ByVal hWnd As Long, ByVal wMsgFilterMin As Long, ByVal wMsgFilterMax As Long, ByVal _ wRemoveMsg As Long) As Long
Private Declare Function WaitMessage Lib "user32" () As Long
Private Type POINTAPI
x As Long
y As Long
End Type
Private Type Msg
hWnd As Long
Message As Long
wParam As Long
lParam As Long
time As Long
pt As POINTAPI
End Type
' 声明常数
Private Const MOD_ALT = &H1
Private Const MOD_CONTROL = &H2
Private Const MOD_SHIFT = &H4
Private Const PM_REMOVE = &H1
Private Const WM_HOTKEY = &H312
Private HotKey_Fg As Boolean
Private Sub Form_Load()
Dim Message As Msg
'注册 Ctrl+Y 为热键
RegisterHotKey Me.hWnd, &HBFFF&, MOD_CONTROL, vbKeyY
'RegisterHotKey Me.hWnd, &HBFF2&, MOD_CONTROL, vbKeyU
Me.Show
Form1.Hide
'等待处理消息
HotKey_Fg = False
Do While Not HotKey_Fg
'等待消息
WaitMessage
'检查是否热键被按下
If PeekMessage(Message, Me.hWnd, WM_HOTKEY, WM_HOTKEY, PM_REMOVE) Then
Form1.Show 1
End If
'转让控制权,允许操作系统处理其他事件
DoEvents
Loop
End Sub
Private Sub Form_Unload(Cancel As Integer)
HotKey_Fg = True
'撤销热键的注册
Call UnregisterHotKey(Me.hWnd, &HBFFF&)
End Sub 方法二:SendMessage
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As _ Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
Private Const WM_SETHOTKEY = &H32
Private Const HOTKEYF_SHIFT = &H1
Private Const HOTKEYF_ALT = &H4
Dim l As Long
Dim wHotkey As Long
wHotkey = (HOTKEYF_ALT) * (2 ^ 8) + 65 '定义ALT+A为热键
l = SendMessage(Me.hwnd, WM_SETHOTKEY, wHotkey, 0)
End Sub 10.在状态栏显示无边框窗体图标。
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hWnd _ As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hWnd _ As Long, ByVal nIndex As Long) As Long
Const GWL_STYLE = (-16&)
Const WS_SYSMENU = &H80000
'Make Form's Icon visible in the taskbar
SetWindowLong Me.hWnd, GWL_STYLE, GetWindowLong(Me.hWnd, GWL_STYLE) Or WS_SYSMENU
End Sub 11. 记录窗体的大小及位置和程序中的一些设置
Me.Width = GetSetting(App.Title, Me.Name, "Width", 7200)
Me.Height = GetSetting(App.Title, Me.Name, "Height", 6300)
Me.Top = GetSetting(App.Title, Me.Name, "Top", 100)
Me.Left = GetSetting(App.Title, Me.Name, "Left", 100)
Check1.Value = GetSetting(App.Title, Me.Name, "check1", 0)
End Sub
Call SaveSetting(App.Title, Me.Name, "Width", Me.Width)
Call SaveSetting(App.Title, Me.Name, "Height", Me.Height)
Call SaveSetting(App.Title, Me.Name, "Top", Me.Top)
Call SaveSetting(App.Title, Me.Name, "Left", Me.Left)
Call SaveSetting(App.Title, Me.Name, "check1", Check1.Value)
End Sub 12. 解决mschart控件数据更改时的闪动现象
1、在有MSChart控件的窗体中另外加入一个PictureBox控件,如MSChart1和Picture1。
2、使Picture1和MSChart1大小一致,位置相同(通过左对齐和顶端对齐)。
3、使Picture1在MSChart1前端,设置Picture1的Visible为False,即不可见。只有刷新数据时Picture1才显示。
'刷新数据过程
Private Sub Refresh()
Dim V_newchar() 'n维数组
Picture1.Visible = True
MSChart1.ChartData = V_newchar '给MSChart1重新赋值,即刷新数据
MSChart1.EditCopy '将当前图表的图片复制到剪贴板中
Picture1.Picture = Clipboard.GetData() '给Picture1赋值剪贴板中的图片
End Sub
这样每一次刷新数据时Picture1显示的图片都不会产生闪烁现象
 楼主| 发表于 2005-1-6 11:38:00 | 显示全部楼层
13. 无边框窗体的右键菜单
设计无边框窗体时,如果使用菜单编辑器,就会自动改变成有边框的窗体,此时,可以在另外一个窗体中(一般情况下你的程序应该不止一个窗体的吧,如果真的只有一个,可以利用其他人写的类,添加右键)编辑菜单(VISIBLE属性设为FALSE),然后在本窗体中调用。调用形式如下:
Private Sub Form_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
If Button = 2 Then
PopupMenu Form2.mymenu
End If
End Sub 14.创建圆角无边框窗体
Private Declare Function CreateRoundRectRgn Lib "gdi32" (ByVal X1 As Integer, ByVal Y1 _ As Integer, ByVal X2 As Integer, ByVal Y2 As Integer, ByVal x3 As Integer, ByVal y3 As _ Integer) As Long
Private Declare Function DeleteObject Lib "gdi32" (ByVal hObject As Long) As Long
Private Declare Function SetWindowRgn Lib "user32" (ByVal hwnd As Long, ByVal hrgn As _ Long, ByVal bRedraw As Boolean) As Long
hround = CreateRoundRectRgn(0, 0, ScaleX(Form1.ScaleWidth, vbTwips, vbPixels), _ ScaleY(Form1.ScaleHeight, vbTwips, vbPixels), 20, 20)
SetWindowRgn Me.hwnd, hround, True
DeleteObject hround
End Sub 15.拖动没有标题栏的窗体
方法一:
Private Declare Function ReleaseCapture Lib "user32" () As Long
Private Const HTCAPTION = 2
Private Const WM_NCLBUTTONDOWN = &HA1
Dim ncl As Long
Dim rel As Long
If Button = 1 Then
i = ReleaseCapture()
ncl = SendMessage(hwnd, WM_NCLBUTTONDOWN, HTCAPTION, 0)
End If
End Sub
方法二:回调函数
module:
Public Const GWL_WNDPROC = (-4)
Public Const WM_NCHITTEST = &H84
Public Const HTCLIENT = 1
Public Const HTCAPTION = 2
Declare Function CallWindowProc Lib "user32" Alias "CallWindowProcA" (ByVal _ lpPrevWndFunc As Long, ByVal hWnd As Long, ByVal Msg As Long, ByVal wParam As Long, _ ByVal lParam As Long) As Long
Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hWnd As _
Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hWnd As _
Public prevWndProc As Long
Function WndProc(ByVal hWnd As Long, ByVal Msg As Long, ByVal wParam As Long, ByVal _Param As Long) As Long
WndProc = CallWindowProc(prevWndProc, hWnd, Msg, wParam, lParam)
If Msg = WM_NCHITTEST And WndProc = HTCLIENT Then
WndProc = HTCAPTION
End If
End Function
窗体中:
prevWndProc = GetWindowLong(Me.hWnd, GWL_WNDPROC)
SetWindowLong Me.hWnd, GWL_WNDPROC, AddressOf WndProc
End Sub
SetWindowLong Me.hWnd, GWL_WNDPROC, prevWndProc
End Sub
16. 半透明窗体
Private Declare Function SetLayeredWindowAttributes Lib "user32" (ByVal hwnd As Long, _ ByVal crKey As Long, ByVal bAlpha As Byte, ByVal dwFlags As Long) As Long
Private Const WS_EX_LAYERED = &H80000
Private Const LWA_ALPHA = &H2
Private Const GWL_EXSTYLE = (-20)
Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal _
hwnd As Long, ByVal nIndex As Long) As Long
Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal _
hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
Dim rtn As Long
rtn = GetWindowLong(Me.hwnd, GWL_EXSTYLE) '取的窗口原先的样式
rtn = rtn Or WS_EX_LAYERED ' 使窗体添加上新的样式WS_EX_LAYERED
SetWindowLong Me.hwnd, GWL_EXSTYLE, rtn ' 把新的样式赋给窗体
SetLayeredWindowAttributes Me.hwnd, 0, 200, LWA_ALPHA
End Sub
17.开机启动(函数及常数声明略)
Dim hKey As Long, SubKey As String, Exe As String
SubKey = "Software\Microsoft\Windows\CurrentVersion\Run"
Exe = "可执行文件的路径"
RegCreateKey HKEY_CURRENT_USER, SubKey, hKey
RegSetvalueEx hKey, "autorun", 0, REG_SZ, ByVal Exe,LenB(StrConv(Exe, vbFromUnicode)) + 1
RegCloseKey hKey
End Sub 18.关闭显示器
Const WM_SYSCOMMAND = &H112&
Const SC_MONITORPOWER = &HF170&
SendMessage Me.hwnd, WM_SYSCOMMAND, SC_MONITORPOWER, ByVal 2& '关闭显示器
End Sub
SendMessage Me.hwnd, WM_SYSCOMMAND, SC_MONITORPOWER, ByVal -1& '打开显示器
End Sub 19. 在程序结束时自动关闭由SHELL打开的程序。
Private Const PROCESS_QUERY_INFORMATION = &H400 '关闭由SHELL函数打开的文件
Private Const PROCESS_TERMINATE = &H1
Private Declare Function OpenProcess Lib "kernel32" (ByVal dwDesiredAccess As Long, _ ByVal bInheritHandle As Long, ByVal dwProcessId As Long) As Long
Private Declare Function TerminateProcess Lib "kernel32" (ByVal hProcess As Long, _
ByVal uExitCode As Long) As Long
Dim ProcessId As Long
ProcessId = Shell("notepad.exe.", vbNormalFocus)
End Sub
Dim hProcess As Long
hProcess = OpenProcess(PROCESS_TERMINATE Or PROCESS_QUERY_INFORMATION, False, _ ProcessId)
Call TerminateProcess(hProcess, 3838)
End Sub 20. 关闭、重启计算机
Public Declare Function ExitWindowsEx Lib "user32" Alias "ExitWindowsEx" (ByVal _
uFlags As Long, ByVal dwReserved As Long) As Long
ExitWindowsEx 1,0 关机
ExitWindowsEx 0,1 重新启动
 楼主| 发表于 2005-1-6 11:39:00 | 显示全部楼层
21.显示关机提示框
Private Declare Function SHRestartSystemMB Lib "shell32" Alias "#59" (ByVal hOwner _
As Long, ByVal sExtraPrompt As String, ByVal uFlags As Long) As Long
Const EWX_LOGOFF = 0
Const EWX_SHUTDOWN = 1
Const EWX_REBOOT = 2
Const EWX_FORCE = 4
Const EWX_POWEROFF = 8
SHRestartSystemMB Me.hWnd, PROMPT, EWX_LOGOFF
End Sub 22.右键托盘图标后必须电击他才可以消失,怎么办?
Case WM_RBUTTONUP '鼠标在图标上右击时弹出菜单
SetForegroundWindow Me.hwnd
Me.PopupMenu mnuTray
加一句 SetForegroundWindow Me.hwnd 23. 将progressbar嵌入statusbar中
Private Declare Function SetParent Lib "user32" (ByVal hWndChild As Long, ByVal _ hWndNewParent As Long) As Long
With ProgressBar1
.Max = 1000
Dim i As Integer
For i = 1 To 1000
.Value = i
Next i
End With
End Sub
ProgressBar1.Appearance = ccFlat
SetParent ProgressBar1.hWnd, StatusBar1.hWnd
ProgressBar1.Left = StatusBar1.Panels(1).Left
ProgressBar1.Top = 100
ProgressBar1.Width = StatusBar1.Panels(1).Width - 50
ProgressBar1.Height = StatusBar1.Height - 150
End Sub '相对位置你可以自己再调一下 24.使你的程序界面具有XP风格
产生一个和你的可执行程序同名的后缀为exe.manifest的文件,并和可执行文件放在同一路径中。
代码中加入:
Private Declare Sub InitCommonControls Lib "comctl32.dll" ()
Private Sub Form_Initialize()
InitCommonControls
End Sub
注意:
1 工具栏控件一定要用Microsoft Windows Common Controls 5.0,而不要用Microsoft Windows Common Controls 6.0。因为此 InitCommonControls API函数是位于comctl32.dll(Microsoft Windows Common Controls 5.0控件的动态链接库中)。
2 放在FRAME控件中的单远按钮有些“麻烦”!为了解决此问题,可以将单选按钮放在PICTURE控件中(以PICTURE控件作为容器),再将 PICTURE控件放在FRAME控件中,就可以了。
3 必须编译之后才能看到效果
exe.manifest文件中的内容,可用notepad编辑。
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
<assemblyIdentity
version="1.0.0.0"
processorArchitecture="X86"
name="CompanyName.ProductName.YourApp"
type="win32"
<description>Your application description here.</description>
<dependency>
<dependentAssembly>
<assemblyIdentity
type="win32"
name="Microsoft.Windows.Common-Controls"
version="6.0.0.0"
publicKeyToken="6595b64144ccf1df"
language="*"
</dependentAssembly>
</dependency>
</assembly>
 楼主| 发表于 2005-1-6 11:40:00 | 显示全部楼层
25.如何打印PictureBox中的所有控件 添加另外一个PictureBox,然后:
Private Const WM_PAINT = &HF
Private Const WM_PRINT = &H317
Private Const PRF_CLIENT = &H4&
Private Const PRF_CHILDREN = &H10&
Private Const PRF_OWNED = &H20&
Private Const PHYSICALOFFSETX As Long = 112
Private Const PHYSICALOFFSETY As Long = 113
As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
Private Declare Function GetDeviceCaps Lib "gdi32" (ByVal hdc As Long, ByVal nindex _
As Long) As Long
private Sub Form_Load()
Picture1.AutoRedraw = True
Picture2.AutoRedraw = True
Picture2.BorderStyle = 0
Picture2.Visible = False
End Sub
Dim retval As Long, xmargin As Single, ymargin As Single
Dim x As Single, y As Single
x = 1: y = 1
With Printer
.ScaleMode = vbInches
xmargin = GetDeviceCaps(.hdc, PHYSICALOFFSETX)
xmargin = (xmargin * .TwipsPerPixelX) / 1440
ymargin = GetDeviceCaps(.hdc, PHYSICALOFFSETY)
ymargin = (ymargin * .TwipsPerPixelY) / 1440
Picture2.Width = Picture1.Width
Picture2.Height = Picture1.Height
DoEvents
Picture1.SetFocus
retval = SendMessage(Picture1.hwnd, WM_PAINT, Picture2.hdc, 0)
retval = SendMessage(Picture1.hwnd, WM_PRINT, Picture2.hdc, _
PRF_CHILDREN + PRF_CLIENT + PRF_OWNED)
DoEvents
Printer.Print ""
.PaintPicture Picture2.Image, x - xmargin, y - ymargin
.EndDoc
End With
End Sub 26.冒泡排序如下:
Sub BubbleSort(List() As Double)
Dim First As Double, Last As Double
Dim i As Integer, j As Integer
Dim Temp As Double
First = LBound(List)
Last = UBound(List)
For i = First To Last - 1
For j = i + 1 To Last
If List(i) > List(j) Then
Temp = List(j)
List(j) = List(i)
List(i) = Temp
End If
Next j
Next i
End Sub
27.清空回收站 Private Declare Function SHEmptyRecycleBin Lib "shell32.dll" Alias _
"SHEmptyRecycleBinA" (ByVal hwnd As Long, ByVal pszRootPath As String, _
Private Declare Function SHUpdateRecycleBinIcon Lib "shell32.dll" () As Long
Private Const SHERB_NOCONFIRMATION = &H1
Private Const SHERB_NOPROGRESSUI = &H2
Private Const SHERB_NOSOUND = &H4
Dim retval As Long ' return value
retval = SHEmptyRecycleBin(RecycleBin.hwnd, "", SHERB_NOPROGRESSUI) ' 清空回收站, 确认
' 若有错误出现,则返回回收站图示
If retval <> 0 Then ' error
retval = SHUpdateRecycleBinIcon()
End If
End Sub
' 清空回收站, 不确认
retval = SHEmptyRecycleBin(RecycleBin.hwnd, "", SHERB_NOCONFIRMATION)
' 若有错误出现,则返回回收站图示
End If
Command1_Click
End Sub
28.获得系统文件夹的路径
Private Declare Function GetSystemDirectory Lib "kernel32" Alias _
"GetSystemDirectoryA" (ByVal lpBuffer As String, ByVal nSize As Long) As Long
Dim syspath As String
Dim len5 As Long
syspath = String(255, 0)
len5 = GetSystemDirectory(syspath, 256)
syspath = Left(syspath, InStr(1, syspath, Chr(0)) - 1)
Debug.Print "System Path : "; syspath
End Sub
29.动态增加控件并响应事件
Option Explicit
'通过使用WithEvents关键字声明一个对象变量为新的命令按钮
Private WithEvents NewButton As CommandButton
'增加控件
If NewButton Is Nothing Then
'增加新的按钮cmdNew
Set NewButton = Controls.Add("VB.CommandButton", "cmdNew", Me)
'确定新增按钮cmdNew的位置
NewButton.Move Command1.Left + Command1.Width + 240, Command1.Top
NewButton.Caption = "新增的按钮"
NewButton.Visible = True
End If
End Sub
'删除控件(注:只能删除动态增加的控件)
Else
Controls.Remove NewButton
Set NewButton = Nothing
End If
End Sub
'新增控件的单击事件
Private Sub NewButton_Click()
MsgBox "您选中的是动态增加的按钮!"
End Sub
30.得到磁盘序列号
Function GetSerialNumber(strDrive As String) As Long
Dim SerialNum As Long
Dim Res As Long
Dim Temp1 As String
Dim Temp2 As String
Temp1 = String$(255, Chr$(0))
Temp2 = String$(255, Chr$(0))
Res = GetVolumeInformation(strDrive, Temp1, Len(Temp1), SerialNum, 0, 0, Temp2, _
Len(Temp2))
GetSerialNumber = SerialNum
End Function
调用形式 Label1.Caption = GetSerialNumber("c:\") 31.打开屏幕保护
'我们将要调用的那个消息,在MSDN中搜索WM_SYSCOMMAND就可以找到具体说明
'这个参数指明了我们让系统启动屏幕保护
Const SC_SCREENSAVE = &HF140&
SendMessage Me.hwnd, WM_SYSCOMMAND, SC_SCREENSAVE, 0
End Sub
32.获得本机IP地址
方法一:利用Winsock控件
winsockip.localip
方法二:
Private Const MAX_IP = 255
Private Type IPINFO
dwAddr As Long
dwIndex As Long
dwMask As Long
dwBCastAddr As Long
dwReasmSize As Long
unused1 As Integer
unused2 As Integer
End Type
Private Type MIB_IPADDRTABLE
dEntrys As Long
mIPInfo(MAX_IP) As IPINFO
End Type
Private Type IP_Array
mBuffer As MIB_IPADDRTABLE
BufferLen As Long
End Type
Private Declare Sub CopyMemory Lib "kernel32" Alias "RtlMoveMemory" (Destination _
As Any, Source As Any, ByVal Length As Long)
Private Declare Function GetIpAddrTable Lib "IPHlpApi" (pIPAdrTable As Byte, _
pdwSize As Long, ByVal Sort As Long) As Long
Dim strIP As String
Private Function ConvertAddressToString(longAddr As Long) As String
Dim myByte(3) As Byte
Dim Cnt As Long
CopyMemory myByte(0), longAddr, 4
For Cnt = 0 To 3
ConvertAddressToString = ConvertAddressToString + CStr(myByte(Cnt)) + "."
Next Cnt
ConvertAddressToString = Left$(ConvertAddressToString, Len(ConvertAddressToString) - 1)
End Function
Public Sub Start()
Dim Ret As Long, Tel As Long
Dim bBytes() As Byte
Dim Listing As MIB_IPADDRTABLE
On Error GoTo END1
GetIpAddrTable ByVal 0&, Ret, True
If Ret <= 0 Then Exit Sub
ReDim bBytes(0 To Ret - 1) As Byte
GetIpAddrTable bBytes(0), Ret, False
CopyMemory Listing.dEntrys, bBytes(0), 4
strIP = "你机子上有 " & Listing.dEntrys & " 个 IP 地址。" & vbCrLf
strIP = strIP & "------------------------------------------------" & vbCrLf & vbCrLf
For Tel = 0 To Listing.dEntrys - 1
CopyMemory Listing.mIPInfo(Tel), bBytes(4 + (Tel * Len(Listing.mIPInfo(0)))), Len _(Listing.mIPInfo(Tel))
strIP = strIP & "IP 地址 : " & ConvertAddressToString(Listing.mIPInfo(Tel).dwAddr) & vbCrLf
Next
Exit Sub
END1:
MsgBox "ERROR"
End Sub
Start
MsgBox strIP
End Sub
 楼主| 发表于 2005-1-6 11:41:00 | 显示全部楼层
33. 用键盘方向键控制COMBOX
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" _
ByVal wMsg As Long, _
Const CB_SHOWDROPDOWN = &H14F
Dim bDrop As Boolean
Private isDo As Boolean
Private Sub Combo1_Click()
If Not isDo Then
isDo = True '<----------回置状态
Exit Sub
Else: MsgBox "safd"
End If
End Sub
Private Sub Combo1_DropDown()
bDrop = True
End Sub
Private Sub Combo1_KeyDown(KeyCode As Integer, Shift As Integer)
If KeyCode = 40 Then
isDo = False
SendMessage Combo1.hwnd, CB_SHOWDROPDOWN, 1, 0
ElseIf KeyCode = 38 Then
isDo = False
If Combo1.ListIndex = 0 Then
If bDrop Then
bDrop = False
SendMessage Combo1.hwnd, CB_SHOWDROPDOWN, 0, 0
End If
End If
End If
End Sub
Private Sub Combo1_KeyUp(KeyCode As Integer, Shift As Integer)
If Combo1.Text = Combo1.List(0) Then
isDo = True
End If
End Sub
isDo = True
Combo1.AddItem "abcd"
Combo1.AddItem "abcd1"
Combo1.AddItem "abcd2"
Combo1.AddItem "abcd3"
End Sub
35.VB下的CRC校验程序
一 计算法
计算法就是依据CRC校验码的产生原理来设计程序。其优点是模块代码少,修改灵活,可移植性好。其缺点为计算量大。为了便于理解,这里假 定了三位数据,而多项式码为A001(hex)。
  在窗体上放置一命令按钮Command1,并添加如下代码:   Private Sub Command1_Click()
   Dim CRC() As Byte
   Dim d() As Byte '待传输数据
   ReDim d(2) As Byte
   d(0) = 123
   d(1) = 112
   d(2) = 135
   CRC = CRC16(d) '调用CRC16计算函数
   'CRC(0)为高位
   'CRC(1)为低位
  End Sub
  注意:在数据传输时CRC的低位可能在前,而高位在后。   Function CRC16(data() As Byte) As String
   Dim CRC16Lo As Byte, CRC16Hi As Byte   'CRC寄存器
   Dim CL As Byte, CH As Byte        '多项式码&HA001
   Dim SaveHi As Byte, SaveLo As Byte
   Dim i As Integer
   Dim Flag As Integer
   CRC16Lo = &HFF
   CRC16Hi = &HFF
   CL = &H1
   CH = &HA0
   For i = 0 To UBound(data)
    CRC16Lo = CRC16Lo Xor data(i) '每一个数据与CRC寄存器进行异或
    For Flag = 0 To 7
     SaveHi = CRC16Hi
     SaveLo = CRC16Lo
     CRC16Hi = CRC16Hi \ 2      '高位右移一位
     CRC16Lo = CRC16Lo \ 2      '低位右移一位
     If ((SaveHi And &H1) = &H1) Then '如果高位字节最后一位为1
      CRC16Lo = CRC16Lo Or &H80   '则低位字节右移后前面补1
     End If              '否则自动补0
     If ((SaveLo And &H1) = &H1) Then '如果LSB为1,则与多项式码进行异或
      CRC16Hi = CRC16Hi Xor CH
      CRC16Lo = CRC16Lo Xor CL
     End If
    Next Flag
   Next i
   Dim ReturnData(1) As Byte
   ReturnData(0) = CRC16Hi       'CRC高位
   ReturnData(1) = CRC16Lo       'CRC低位
   CRC16 = ReturnData
  End Function 2.查表法
  查表法的优缺点与计算法的正好相反。为了便于比较,这里所有的假定与计算法的完全相同,都而在窗体上放置一个Command1的按钮,其 代码部分与上面的也完全一致。下面只介绍CRC函数的编写源代码。   Private Function CRC16(data() As Byte) As String
   Dim CRC16Hi As Byte
   Dim CRC16Lo As Byte
   CRC16Hi = &HFF
   CRC16Lo = &HFF
   Dim i As Integer
   Dim iIndex As Long
    iIndex = CRC16Lo Xor data(i)
    CRC16Lo = CRC16Hi Xor GetCRCLo(iIndex)    '低位处理
    CRC16Hi = GetCRCHi(iIndex)          '高位处理
   Next i
   CRC16 = ReturnData
  End Function   'CRC低位字节值表
  Function GetCRCLo(Ind As Long) As Byte
   GetCRCLo = Choose(Ind + 1, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, _
&H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40, &H1, &HC0, &H80, &H41, &H1, &HC0, &H80, &H41, &H0, &HC1, &H81, &H40)
  End Function   'CRC高位字节值表
  Function GetCRCHi(Ind As Long) As Byte
   GetCRCHi = Choose(Ind + 1, &H0, &HC0, &HC1, &H1, &HC3, &H3, &H2, &HC2, &HC6, &H6, &H7, &HC7, &H5, &HC5, &HC4, &H4, &HCC, &HC, &HD, &HCD, &HF, &HCF, &HCE, &HE, &HA, &HCA, &HCB, &HB, &HC9, &H9, &H8, &HC8, &HD8, &H18, &H19, &HD9, &H1B, &HDB, &HDA, &H1A, &H1E, &HDE, &HDF, &H1F, &HDD, &H1D, &H1C, &HDC, &H14, &HD4, &HD5, &H15, &HD7, &H17, &H16, &HD6, &HD2, &H12, &H13, &HD3, &H11, &HD1, &HD0, &H10, &HF0, &H30, &H31, &HF1, &H33, &HF3, &HF2, &H32, &H36, &HF6, &HF7, &H37, &HF5, &H35, &H34, &HF4, &H3C, &HFC, &HFD, &H3D, &HFF, &H3F, &H3E, &HFE, &HFA, &H3A, &H3B, &HFB, &H39, &HF9, &HF8, &H38, &H28, &HE8, &HE9, &H29, &HEB, &H2B, &H2A, &HEA, &HEE, &H2E, &H2F, &HEF, &H2D, &HED, &HEC, &H2C, &HE4, &H24, &H25, &HE5, &H27, &HE7, &HE6, &H26, &H22, &HE2, &HE3, &H23, &HE1, &H21, &H20, &HE0, &HA0, &H60, _
&H61, &HA1, &H63, &HA3, &HA2, &H62, &H66, &HA6, &HA7, &H67, &HA5, &H65, &H64, &HA4, &H6C, &HAC, &HAD, &H6D, &HAF, &H6F, &H6E, &HAE, &HAA, &H6A, &H6B, &HAB, &H69, &HA9, &HA8, &H68, &H78, &HB8, &HB9, &H79, &HBB, &H7B, &H7A, &HBA, &HBE, &H7E, &H7F, &HBF, &H7D, &HBD, &HBC, &H7C, &HB4, &H74, &H75, &HB5, &H77, &HB7, &HB6, &H76, &H72, &HB2, &HB3, &H73, &HB1, &H71, &H70, &HB0, &H50, &H90, &H91, &H51, &H93, &H53, &H52, &H92, &H96, &H56, &H57, &H97, &H55, &H95, &H94, &H54, &H9C, &H5C, &H5D, &H9D, &H5F, &H9F, &H9E, &H5E, &H5A, &H9A, &H9B, &H5B, &H99, &H59, &H58, &H98, &H88, &H48, &H49, &H89, &H4B, &H8B, &H8A, &H4A, &H4E, &H8E, &H8F, &H4F, &H8D, &H4D, &H4C, &H8C, &H44, &H84, &H85, &H45, &H87, &H47, &H46, &H86, &H82, &H42, &H43, &H83, &H41, &H81, &H80, &H40)
  End Function
36.如何打开光驱
Public Declare Function CDdoor Lib "winmm.dll" Alias "mciSendStringA" (ByVal lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As Long, ByVal hwndCallback As Long) As Long
Call CDdoor("set CDAudio door open", 0, 0, 0) '打开光驱
Call CDdoor("set CDAudio door closed", 0, 0, 0) '关闭光驱
 楼主| 发表于 2005-1-6 11:43:00 | 显示全部楼层
37.检测是否以联网及联网方式
module:
Public Declare Function InternetGetConnectedStateEx Lib "wininet.dll" _
Alias "InternetGetConnectedStateExA" _
(ByRef lpdwFlags As Long, _
ByVal lpszConnectionName As String, _
ByVal dwNameLen As Long, _
ByVal dwReserved As Long _
) As Long Public Enum EIGCInternetConnectionState
INTERNET_CONNECTION_MODEM = &H1&
INTERNET_CONNECTION_LAN = &H2&
INTERNET_CONNECTION_PROXY = &H4&
INTERNET_RAS_INSTALLED = &H10&
INTERNET_CONNECTION_OFFLINE = &H20&
INTERNET_CONNECTION_CONFIGURED = &H40&
End Enum Public Property Get InternetConnected( _
Optional ByRef eConnectionInfo As EIGCInternetConnectionState, _
Optional ByRef sConnectionName As String _
) As Boolean
Dim dwFlags As Long
Dim sNameBuf As String
Dim lR As Long
Dim iPos As Long
sNameBuf = String$(513, 0)
lR = InternetGetConnectedStateEx(dwFlags, sNameBuf, 512, 0&)
eConnectionInfo = dwFlags
iPos = InStr(sNameBuf, vbNullChar)
If iPos > 0 Then
sConnectionName = Left$(sNameBuf, iPos - 1)
ElseIf Not sNameBuf = String$(513, 0) Then
sConnectionName = sNameBuf
End If
InternetConnected = (lR = 1)
End Property
窗体中
' Determine whether we have a connection:
bConnected = InternetConnected(eR, sName) ' The connection state info parameter provides details
' about how we connect:
If (eR And INTERNET_CONNECTION_MODEM) = INTERNET_CONNECTION_MODEM Then
sMsg = sMsg & "Connection uses a modem." & vbCrLf
End If
If (eR And INTERNET_CONNECTION_LAN) = INTERNET_CONNECTION_LAN Then
sMsg = sMsg & "Connection uses LAN." & vbCrLf
End If
If (eR And INTERNET_CONNECTION_PROXY) = INTERNET_CONNECTION_PROXY Then
sMsg = sMsg & "Connection is via Proxy." & vbCrLf
End If
If (eR And INTERNET_CONNECTION_OFFLINE) = INTERNET_CONNECTION_OFFLINE Then
sMsg = sMsg & "Connection is Off-line." & vbCrLf
End If
If (eR And INTERNET_CONNECTION_CONFIGURED) = INTERNET_CONNECTION_CONFIGURED Then
sMsg = sMsg & "Connection is Configured." & vbCrLf
Else
sMsg = sMsg & "Connection is Not Configured." & vbCrLf
End If
If (eR And INTERNET_RAS_INSTALLED) = INTERNET_RAS_INSTALLED Then
sMsg = sMsg & "System has RAS installed." & vbCrLf
End If
' Display the connection name and info:
If bConnected Then
Text1.Text = "Connected: " & sName & vbCrLf & vbCrLf & sMsg
Else
Text1.Text = "Not Connected: " & sName & vbCrLf & vbCrLf & sMsg
End If
End Sub 38.得到当前windows的版本号 module:
Type OSVERSIONINFO
dwOSVersionInfoSize As Long
dwMajorVersion As Long
dwMinorVersion As Long
dwBuildNumber As Long
dwPlatformId As Long
szCSDVersion As String * 128 ' Maintenance string for PSS usage
End Type
Declare Function GetVersionEx Lib "kernel32" Alias "GetVersionExA" (lpVersionInformation As OSVERSIONINFO) As Long
Declare Function GetSystemMetrics Lib "user32" (ByVal nIndex As Long) As Long
Public Const SM_CLEANBOOT = 67
Public Const SM_DEBUG = 22
Public Const SM_SLOWMACHINE = 73
Public Const VER_PLATFORM_WIN32s = 0
Public Const VER_PLATFORM_WIN32_WINDOWS = 1
Public Const VER_PLATFORM_WIN32_NT = 2
窗体中 Private Sub Form_Load()
Dim myVer As OSVERSIONINFO
Dim nl As String
Dim q As Long
nl = Chr(10) & Chr(13)
myVer.dwOSVersionInfoSize = 148
q& = GetVersionEx(myVer)
lblWininfo = ""
lblMoreWininfo = ""
If myVer.dwPlatformId = VER_PLATFORM_WIN32_WINDOWS Then lblWininfo = lblWininfo & "运行平台 = Windows 95/98" & nl
If myVer.dwPlatformId = VER_PLATFORM_WIN32_NT Then lblWininfo = lblWininfo & "Platform = Windows NT" & nl
lblWininfo = lblWininfo & "Version = " & myVer.dwMajorVersion & "." & myVer.dwMinorVersion & " 创建于 " & (myVer.dwBuildNumber And &HFFFF&) & nl
lblMoreWininfo = "Windows 现在运行在"
If GetSystemMetrics(SM_CLEANBOOT) = 0 Then lblMoreWininfo = lblMoreWininfo & "正常模式" & nl
If GetSystemMetrics(SM_CLEANBOOT) = 1 Then lblMoreWininfo = lblMoreWininfo & "安全模式" & nl
If GetSystemMetrics(SM_CLEANBOOT) = 2 Then lblMoreWininfo = lblMoreWininfo & "局域网安全模式" & nl
If GetSystemMetrics(SM_DEBUG) = True Then lblMoreWininfo = lblMoreWininfo & "Windows Debugging Mode in operation" & nl
If GetSystemMetrics(SM_SLOWMACHINE) = True Then lblMoreWininfo = lblMoreWininfo & "这台PC配置太低无法高效运行 Windows." & nl
End Sub 39.模拟键盘
Private Declare Sub keybd_event Lib "user32" _
(ByVal bVk As Byte, _
ByVal dwFlags As Long, _
Private Const VK_LWIN = &H5B
Private Const KEYEVENTF_KEYUP = &H2
Private Const VK_APPS = &H5D
Private Const VK_PLAY = &HFA
Private Sub DoAction(Index As Integer)
Dim VK_ACTION As Long
Select Case Index
Case 0: '打开资源管理器
VK_ACTION = &H45
Case 1: '查找文件
VK_ACTION = &H46
Case 2: '最小化所有窗口
VK_ACTION = &H4D
Case 3: '运行程序
VK_ACTION = &H52
Case 4: '弹出Win菜单
VK_ACTION = &H5B
Case 5: '将计算机转如睡眠状态
VK_ACTION = &H5E
Case 6: '执行Windows帮助
VK_ACTION = &H70
End Select
Call keybd_event(VK_LWIN, 0, 0, 0)
Call keybd_event(VK_ACTION, 0, 0, 0)
Call keybd_event(VK_LWIN, 0, KEYEVENTF_KEYUP, 0)
End Sub 40 延迟函数 Public Sub Delay(DelayTime As Single)
Dim BeginTime As Single
BeginTime = Timer
While Timer < BeginTime + DelayTime
DoEvents
Wend
End Sub
调用形式 delay 1.5
或者用Sleep函数
GMT+8, 2025-10-11 10:50 , Processed in 0.188333 second(s), 27 queries , Gzip On.
