查看: 1363|回复: 2
[VBA] 如何交互取点
发表于 2005-1-17 14:25:00 | 显示全部楼层 |阅读模式
vba 我把帮助里的代码放到按钮里,会出现错误,求助 Dim returnPnt As Variant
' Return a point using a prompt
returnPnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2) & vbCrLf & _
"(Enter the next value without prompting.)", , "GetPoint Example"
' Return a point, no prompt
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetPoint Example"
' Return a point using a base point and a prompt
Dim basePnt(0 To 2) As Double
basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
' Create a line from the base point and the last point entered
Dim lineObj As AcadLine
Set lineObj = ThisDrawing.ModelSpace.AddLine(basePnt, returnPnt)
ZoomAll
发表于 2005-1-17 16:08:00 | 显示全部楼层
前面加me.hide
后面加me.show
 楼主| 发表于 2005-1-17 16:41:00 | 显示全部楼层
谢谢
GMT+8, 2025-6-2 09:18 , Processed in 0.156102 second(s), 23 queries , Gzip On.
