查看: 1228|回复: 0
[求助] 如何交互输入 2004
发表于 2005-1-17 14:29:00 | 显示全部楼层 |阅读模式
vba 我把代码放到按钮里,执行时出现主窗口不存在 Dim returnPnt As Variant
' Return a point using a prompt
returnPnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2) & vbCrLf & _
"(Enter the next value without prompting.)", , "GetPoint Example"
' Return a point, no prompt
MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetPoint Example"
' Return a point using a base point and a prompt
Dim basePnt(0 To 2) As Double
basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
' Create a line from the base point and the last point entered
Dim lineObj As AcadLine
Set lineObj = ThisDrawing.ModelSpace.AddLine(basePnt, returnPnt)
ZoomAll
参与人数 1金钱 -5 贡献 -1 激情 -2 收起 理由
雪山飞狐_lzh -5 -1 -2 【差评】重复发贴
GMT+8, 2025-6-2 09:42 , Processed in 0.234953 second(s), 27 queries , Gzip On.
