查看: 1524|回复: 1
复制的关于AddHatch的例子,为何不能运行??
发表于 2005-1-20 20:11:00 | 显示全部楼层 |阅读模式
我复制的AutoCAD VBA帮助中的例子(AppendOuterLoop ),为什么不能运行?能帮我看看吗? 这是个填充半圆的例子. 倒数第二行(hatchObj.Evaluate)语句总是不能运行. ------------------------------------ Sub Example_AppendOuterLoop()
' This example creates an associative hatch in model space.
Dim hatchObj As AcadHatch
Dim patternName As String
Dim PatternType As Long
Dim bAssociativity As Boolean
' Define the hatch
patternName = "ANSI31"
PatternType = 0
bAssociativity = True
' Create the associative Hatch object
Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
' Create the outer loop for the hatch.
' An arc and a line are used to create a closed loop.
Dim outerLoop(0 To 1) As AcadEntity
Dim center(0 To 2) As Double
Dim radius As Double
Dim startAngle As Double
Dim endAngle As Double
center(0) = 5: center(1) = 3: center(2) = 0
radius = 1
startAngle = 0
endAngle = 3.141592
Set outerLoop(0) = ThisDrawing.ModelSpace.AddArc(center, radius, startAngle, endAngle)
Set outerLoop(1) = ThisDrawing.ModelSpace.AddLine(outerLoop(0).EndPoint, outerLoop(0).StartPoint)
' Append the outer loop to the hatch object, and display the hatch
hatchObj.AppendOuterLoop (outerLoop)
hatchObj.Evaluate
ZoomAll
End Sub
发表于 2005-1-20 21:12:00 | 显示全部楼层
原因:比例太大,造成要填充的面积中不能出现填充图案,所以出错。
可以修改圆弧的半径,或在Set hatchObj...后增加:
hatchObj.PatternScale = 0.2
GMT+8, 2025-6-2 11:10 , Processed in 0.162273 second(s), 23 queries , Gzip On.
