查看: 1786|回复: 2
一个问题,不得其解了,请帮忙看下
发表于 2005-1-23 11:04:00 | 显示全部楼层 |阅读模式
我想在一条线上(由多条line,pline组成)选中一段线,自动找出整条线,用红色显示,该线的各线段名称(ename)保存在mline的列表中,我判断的时候将已经找出的线段排除了(itemexist 判断),可是结果还是会重复已经找出的线段,请各位看看这是哪里错了,3ks!
发表于 2005-1-23 11:23:00 | 显示全部楼层
贴出你的程序段,别人才好判断。
 楼主| 发表于 2005-1-24 10:30:00 | 显示全部楼层
本来上传了的,现在写在下面,帮忙看下:),主程序是findline (defun ptinpl (ename n)
(setq ent (entget ename))
(setq i (+ 14 (* (- n 1) 4)))
(cdr (nth i ent))
;(list (nth (* n 2) plist)(nth (1+ (* n 2)) plist))
) (defun ptnofpl(ename)
(/ (- (length ent) 15) 4)
) (defun itemexist(mlist item / bu len i)
(setq bu nil)
(setq len (length mlist) i (- len 1))
(while (>= i 0)
(if (= (nth i mlist) item) (setq bu t i 0))
(setq i (- i 1))
bu
(defun c:findline()
(setq lstart nil) ;;line name list
(while (not lstart)
(setq lstart (car (entsel "\n选择线的起始线:")))
(setq ltype (cdr (assoc 0 (entget lstart))))
(if (= (strcase ltype) "LINE")
(setq pt1 (cdr (assoc 10 (entget lstart))) pt2 (cdr (assoc 11 (entget lstart))))
(setq pt1 (ptinpl lstart 1) pt2 (ptinpl lstart (ptnofpl lstart)))
(setq ssl (ssget "x" (list (cons 0 "line"))))
(setq sspl (ssget "x" (list (cons 0 "LWPOLYLINE"))))
(setq lno (sslength ssl))
(setq plno (sslength sspl))
(setq num (+ lno plno))
(setq isend nil)
(setq mline (list lstart)) (setq count 0)
(while (not isend)
(setq i 0 isend t)
(while (< i num)
(if (< i lno)
(setq ename (ssname ssl i))
(setq ename (ssname sspl (- i lno)))
(if (not (itemexist mline ename))(progn
(setq ltype (cdr (assoc 0 ent)))
(if (< i lno)
(setq tpt1 (cdr (assoc 10 ent)) tpt2 (cdr (assoc 11 ent)))
(setq tpt1 (ptinpl ename 1) tpt2 (ptinpl ename (ptnofpl ename)))
(if (= (distance tpt1 pt2) 0)
(setq mline (append mline (list ename)))
(setq pt2 tpt2 isend nil i num)
(if (= (distance tpt1 pt1) 0)
(setq pt1 tpt2 isend nil i num)
(if isend
(if (= (distance tpt2 pt1) 0)
(setq pt1 tpt1 isend nil i num)
(if (= (distance tpt2 pt2) 0)
(setq pt2 tpt1 isend nil i num)
(setq i (+ i 1))
(setq count (+ count 1))
(if (>= count 20)(setq isend t))
) (foreach i mline
(command "change" i "" "p" "c" "1" "")
GMT+8, 2025-12-30 05:58 , Processed in 0.156398 second(s), 25 queries , Gzip On.
