查看: 1594|回复: 2
请各位帮忙查我程序中的一点小错误
发表于 2005-1-24 11:03:00 | 显示全部楼层 |阅读模式
Sub 拟合求视速度1()
Dim n As Integer, vp As Integer, i As Integer, k As Integer
Dim x(1 To 2000) As Double
Dim y(1 To 2000) As Double
Dim da As Double, db As Double, a00 As Double, a01 As Double, a10 As Double
Dim a11 As Double, c0 As Double, c1 As Double, f0 As Double, fn As Double, height As Double
Dim lineObj As AcadLine
Dim textString As String
Dim startPoint(0 To 2) As Double
Dim endPoint(0 To 2) As Double
Dim sset As AcadSelectionSet
Dim pline As AcadLWPolyline
ThisDrawing.Utility.Prompt "请选择要拟合的曲线:"
Set sset = ThisDrawing.SelectionSets.Add("SS1")
sset.SelectOnScreen
Set pline = sset.Item(0)
Dim retCoord As Variant
retCoord = pline.Coordinates
pline.Delete
i = 1
k = 0
Do While i <= 24
x(i) = retCoord(k)
y(i) = retCoord(k + 1)
i = i + 1
k = k + 3
Loop
n = 24
a00 = n
a01 = 0#
For i = 1 To n
a01 = a01 + x(i)
Next
a10 = a01
a11 = 0
For i = 1 To n
a11 = a11 + x(i) * x(i)
Next
c0 = 0
For i = 1 To n
c0 = c0 + y(i)
Next
c1 = 0
For i = 1 To n
c1 = c1 + x(i) * y(i)
Next
db = (c0 * a10 - c1 * a00) / (a01 * a10 - a00 * a11)
da = (c0 * a11 - c1 * a01) / (a11 * a00 - a01 * a10)
f0 = da + db * x(1)
fn = da + db * x(n)
startPoint(0) = x(1): startPoint(1) = f0: startPoint(2) = 0#
endPoint(0) = x(n): endPoint(1) = fn: endPoint(2) = 0#
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
height = 4
vp = 1000 / db
textString = "vp" & "=" & vp
Set blockObj = ThisDrawing.ModelSpace.AddText(textString, endPoint, height)
End Sub
在给x(i),y(i)赋值时可能“Coordinates”属性搞错了,请各位师父改一下!
发表于 2005-1-24 11:57:00 | 显示全部楼层
AutoCAD上的帮助文件对坐标值是这么说的:
Coordinates Variant (array of doubles); read-write
The array of points. LightweightPolyline objects: The variant is an array of 2D points in OCS. Polyline objects: The variant is an array of 3D points: the X and Y coordinates are in OCS;
the Z coordinate is ignored. All other objects: The variant is an array of 3D points in WCS.
你定义了Dim pline As AcadLWPolyline,所以pline.Coordinates返回的是两维数据(XY坐标值)的列表。
 楼主| 发表于 2005-1-25 11:00:00 | 显示全部楼层
谢谢楼上的朋友,已搞定!
GMT+8, 2025-6-23 04:56 , Processed in 0.163754 second(s), 23 queries , Gzip On.
