查看: 1869|回复: 2
发掘AutoLISP的潜力
发表于 2005-2-1 20:36:00 | 显示全部楼层 |阅读模式
发表于 2005-2-1 22:50:00 | 显示全部楼层
What?
发表于 2005-2-2 07:53:00 | 显示全部楼层
;; Program Name: GetIcon.lsp [Get Icon R5]
;; Created By: Terry Miller (Email: terrycadd@yahoo.com)
;; Date Created: 4-1-00
;; Function: Various dialog Get functions enhanced with the icons AlertX,
;; Block, Computer, Delete, Exclam, Filefolder, Folder, Frown, Inform, Printer,
;; Quest, Replace, Smile and None. These functions and utilities get the true
;; dialog string widths to create a C:\Temp\Temp.dcl dialog file on the fly and
;; return a string of the name of the button selected.
;; Revision History
;; Rev By Date Description
;; 1 TM 4-1-00 Initial version
;; 2 TM 12-1-00 Revised functions to allow up to 4 lines and to allow
;; choosing different icons.
;; 3 TM 1-1-01 Added Printer, Smile and Frown icons.
;; 4 TM 7-21-03 Added EditBox for entering string values.
;; Syntax: (EditBox "Title" "Label" "EditText" EditWidth)
;; 5 TM 5-20-04 Revised functions to allow up to 10 lines closer together,
;; and added the None option of not including an icon.
;; Overview of Main Functions
;; c:GetIcon - [GetIcon Help] - Displays GetIcon Get functions and syntax.
;; GetOK - Returns "OK"
;; GetOKCancel - Returns "OK" or "Cancel"
;; GetYesNo - Returns "Yes" or "No"
;; GetYesNoCancel - Returns "Yes", "No" or "Cancel"
;; GetYestoAll - Returns "Yes", "Yes to All", "No" or "Cancel"
;; GetRetryCancel - Returns "Retry" or "Cancel"
;; TempDcl - Creates a Temp.dcl dialog file and returns the button selected.
;; GetDclWidth - Get the true dialog string width.
;; GetPT [Get integer Points] - Utility for vector_line.
;; vector_circle - Draws vector circles, arcs and ellipses in an image tile.
;; vector_line - Draws vector lines in an image tile.
;; c:Vector_Circle - Vector_Circle Dialog Examples <-- Try It!
;; dtr - Degrees to Radians function
;; EditBox - Dialog for entering string values.
GMT+8, 2025-2-19 07:07 , Processed in 0.143246 second(s), 27 queries , Gzip On.
