查看: 2386|回复: 0
请教GetObject(, "AutoCAD.Application")语句的应用?
发表于 2005-2-2 09:04:00 | 显示全部楼层 |阅读模式
Private Sub Command1_Click()
On Error Resume Next
Dim dwgname As String
dwgname = "c:\Test.dwg" '测试用,事先画一张Test.dwg
If Dir(dwgname) <> "" Then
Dim acadApp As AcadApplication
Set acadApp = GetObject(, "AutoCAD.Application.14") '原先测试时是(,"AutoCAD.Application"),程序可以运行
If Err Then
Err.Clear
Set acadApp = CreateObject("AutoCAD.Application.14")
If Err Then
MsgBox Err.Description
Exit Sub
End If
End If
Dim acadDoc As AcadDocuments
Set acadDoc = acadApp.Documents
acadDoc.Open (dwgname)
acadApp.Visible = True
acadApp.ZoomExtents
Else
MsgBox "文件" & dwgname & "不存在,"
End If
End Sub 原程序在第7行时是Set acadApp = GetObject(, "AutoCAD.Application"),该程序可以通过AutoCAD2002打开图纸Test.dwg,现因某些原因需要通过AutoCAD R14来打开图纸。(系统中装有CAD2002和CAD-R14) ,但做了相应更改后,程序报错:类型不匹配!请问这是什么原因??
GMT+8, 2025-10-11 11:04 , Processed in 0.242716 second(s), 23 queries , Gzip On.
