查看: 2187|回复: 4
关于objectarx2005在vs.net2003中的应用
发表于 2005-2-16 15:42:00 | 显示全部楼层 |阅读模式
我先装了vs.net2003试了很多方法都不好实现。如果一定要在2003下用,可参考如下:http://863s.com/list.asp?unid=143,发现好多网站都说不好实现,我便又装了vs.net2002,刚装好,运行一下后,发现自已错了,原来运行时提示更新,我看了下说明,原来AutoDesk公司已经在最新的更新中解决了这个另人难受的问题。如下: Version 3.2.0.0: * New feature list: - Now install on both .NET 2002 and 2003 (NOTE you must use VC7.0 still) - Dropped ARX Help button in favor of the Integrated Visual Studio Help (See DevNote #83661) - Dropped 'Code Finder' button in favor of the Dynamic Help from the Integrated Visual Studio Help (See DevNote #83661) - Code Gallery is now available (and synchronized with ADN) - LiveUpdate is not anymore automatic - acad.rx generation is turned off by default.
* Bugfix list: - ACE - Add Class wizards adding class to the wrong project - ARX Command Wizard not working on .NET 2003 - Member Variable Wizard not working on localized Visual Studio .NET releases - Eratic Unhandled Exception on Wizard launch - Eratic loose of Wizards configuration Version 3.0.0.0: * Shipping version
发表于 2005-2-19 16:11:00 | 显示全部楼层
reply
请问这些环境变量应该怎么设置,手动设置吗?
我不会,请告诉我.
发表于 2005-2-20 11:37:00 | 显示全部楼层
我想学ARX,可至今还不知道要装什么程序,我的系统是xp,cad2004,怎么装,谢谢了
发表于 2005-2-26 16:26:00 | 显示全部楼层
至少找个VC6.0和ObjectARX2000版本装上,要用CAD2004,最好装VC7.0(.net 2002)和ObjectARX2004.
发表于 2005-2-27 17:51:00 | 显示全部楼层
GMT+8, 2025-4-22 12:29 , Processed in 0.169232 second(s), 32 queries , Gzip On.
