查看: 2465|回复: 5
如何把.PAT文件所属的文件路径用VBA程序自动添加到AUTOCAD的支持文件搜索路径中.
发表于 2005-2-20 19:48:00 | 显示全部楼层 |阅读模式
如何把.PAT文件所属的文件路径用VBA程序自动添加到AutoCAD的支持文件搜索路径中.即我把.PAT文件保存在 "E:\工程项目\SUPPORT\" 文件夹中,如何用VBA语言编程自动添加到AUTOCAD2002 >TOOLS>OPTIONS>SUPPORT FILE SERACH PATH 中.
发表于 2005-2-20 22:03:00 | 显示全部楼层
 楼主| 发表于 2005-2-21 17:35:00 | 显示全部楼层
能否写具体点,谢谢
发表于 2005-2-21 19:19:00 | 显示全部楼层
Sub Example_SupportPath()
' This example returns the current setting of
' SupportPath. It then changes the value, and finally
' it resets the value back to the original setting.
Dim preferences As AcadPreferences
Dim currSupportPath As String
Dim newSupportPath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current SupportPath value
currSupportPath = preferences.Files.SupportPath
MsgBox "The current value for SupportPath is " & currSupportPath, vbInformation, "SupportPath Example"
' Change the value for SupportPath
newSupportPath = "TestSupportPath"
preferences.Files.SupportPath = newSupportPath
MsgBox "The new value for SupportPath is " & newSupportPath, vbInformation, "SupportPath Example"
' Reset SupportPath to its original value
preferences.Files.SupportPath = currSupportPath
MsgBox "The SupportPath value is reset to " & currSupportPath, vbInformation, "SupportPath Example"
End Sub
发表于 2005-2-22 11:03:00 | 显示全部楼层
Sub AddSupportPath(ByVal Path As String)
Dim curSupportPath As Variant
Dim i As Integer
Dim Support As Boolean Support = False
curSupportPath = Split(ThisDrawing.Application.preferences.Files, ";") For i = 0 To UBound(curSupportPath)
If StrConv(curSupportPath(i), vbUpperCase) = StrConv(Path, vbUpperCase) Then
Support = True
Exit For
End If
Next If Not Support Then
ThisDrawing.Application.preferences.Files = ThisDrawing.Application.preferences.Files & ";" & Path
End If End Sub Sub test()
AddSupportPath "d:\test"
End Sub
发表于 2012-2-8 18:25:15 | 显示全部楼层
楼上讲的是inventor吗?
GMT+8, 2025-4-30 07:41 , Processed in 0.154802 second(s), 25 queries , Gzip On.
