查看: 3138|回复: 1
如何用VB.NET的ARX方法生成面域
发表于 2005-2-22 11:39:00 | 显示全部楼层 |阅读模式
我写了一段代码,先画一个圆,再生成面域。结果圆能画出,面域却创建失败,请各位高手看看错在哪?先谢谢了! Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Public Class Class1
<CommandMethod("test")> Public Shared Sub TestTemp()
Dim bt As BlockTable
Dim btr As BlockTableRecord Dim CenPt As New Point3d(0, 0, 0) '先画一个圆
Dim CircleObj As Circle
Try
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim objId As ObjectId = db.BlockTableId bt = objId.Open(OpenMode.ForRead)
objId = bt.Item(btr.ModelSpace)
btr = objId.Open(OpenMode.ForWrite)
CircleObj = New Circle
CircleObj.Center = CenPt
CircleObj.Radius = 300
btr.AppendEntity(CircleObj)
Catch
Finally
CircleObj.Close()
btr.Close()
bt.Close()
End Try
Dim Array As DBObjectCollection = New DBObjectCollection '建立一个集合
Array.Add(CircleObj) '将圆添加到集合中 Dim Reginobj As Region
Try
ReginObj = New Region
Region.CreateFromCurves(Array)
btr.AppendEntity(Reginobj)
Catch
Finally
Reginobj.Close()
btr.Close()
bt.Close()
End Try
End Sub
End Class
发表于 2007-4-5 16:15:00 | 显示全部楼层
返回的是dbobjectcollection类型
你的ReginObj 还是null,并没有付给它
GMT+8, 2025-5-13 18:39 , Processed in 0.197394 second(s), 23 queries , Gzip On.
