查看: 1926|回复: 4
VBA中范围打印命令是什么?
发表于 2005-2-24 12:03:00 | 显示全部楼层 |阅读模式
VBA中有显示打印、根据图纸大小打印等,VBA中范围打印命令是什么?
发表于 2005-2-24 12:40:00 | 显示全部楼层
object.SetWindowToPlot(LowerLeft, UpperRight)
Object
MSITStore:D:\AutoCAD%202005\help\acadauto.chm::/idh_layout_object.htm" target="_blank" >Layout, MSITStore:D:\AutoCAD%202005\help\acadauto.chm::/idh_plotconfiguration_object.htm" target="_blank" >PlotConfiguration
The object or objects this method applies to.
LowerLeft
Variant (two-element array of doubles); input-only
The X and Y values for the lower-left window.
UpperRight
The X and Y values for the upper-right window.
 楼主| 发表于 2005-2-24 20:54:00 | 显示全部楼层
可以加上注释吗?
 楼主| 发表于 2005-2-24 20:56:00 | 显示全部楼层
Private Sub CommandButton1_Click()
ThisDrawing.PaperSpace.Layout.ConfigName = "hp laserjet 1000"
' 到布局
If ThisDrawing.ActiveSpace = acModelSpace Then
ThisDrawing.ActiveSpace = acPaperSpace
ThisDrawing.MSpace = False
ZoomExtents
End If
'打印落在选定空间内的全部内容
ThisDrawing.PaperSpace.Layout.PlotType = acExtents
'设计为草图打印,不计比例
ThisDrawing.PaperSpace.Layout.StandardScale = acScaleToFit
' 设置打印份数为1
ThisDrawing.Plot.NumberOfCopies = a
' 开始打印
ThisDrawing.Plot.PlotToDevice
Unload UserForm8
' 到模型
If ThisDrawing.ActiveSpace = acPaperSpace Then
ThisDrawing.MSpace = True
End If
End Sub
 楼主| 发表于 2005-2-25 21:25:00 | 显示全部楼层
如4楼程序所示,是我编的一个程序,启动CAD后,用程序画的第一个图,可以全图打印,删除此图,再次用程序划图,再次打印时,总是不能全图打印,是否如下语名有问题?
'打印落在选定空间内的全部内容
GMT+8, 2025-6-4 01:21 , Processed in 0.163786 second(s), 23 queries , Gzip On.
