查看: 1698|回复: 1
[求助]主窗口不可见是什么问题
发表于 2005-3-2 11:15:00 | 显示全部楼层 |阅读模式
Private Sub CommandButton1_Click()
Dim DataType(0 To 1) As Integer
Dim Data(0 To 1) As Variant
DataType(0) = 1001: Data(0) = TextBox1.Text
DataType(1) = 1000: Data(1) = "String" Dim ssetObj As AcadSelectionSet
Dim elem As AcadObject
On Error Resume Next
ThisDrawing.SelectionSets("text").Delete
Set ssetObj = ThisDrawing.SelectionSets.Add("text")
Err.Clear
On Error GoTo 0
' Add objects to a selection set by prompting user to select on the screen
'While (True)
selectagain:
ssetObj.SelectOnScreen
For Each elem In ssetObj Next
' Wend
If ssetObj.Count <> 0 Then
ssetObj.Clear
GoTo selectagain
End If
ssetObj.Delete
End Sub 在运行到 ssetObj.SelectOnScreen
时 提示错误:主窗口不可见 请问怎么可以解决啊?
 楼主| 发表于 2005-3-2 11:18:00 | 显示全部楼层
哦,解决了。
showmodel=false
旧问题了。
GMT+8, 2025-6-4 01:25 , Processed in 0.178775 second(s), 23 queries , Gzip On.
