查看: 4344|回复: 1
问获取当前视口(Viewport)坐标值的函数
发表于 2005-3-2 17:11:00 | 显示全部楼层 |阅读模式
rt
3x a lot!
 楼主| 发表于 2005-3-3 10:36:00 | 显示全部楼层
在ObjectARX Developer's Guide 里找到了
Example 3: Obtaining the Window Coordinates
This example shows the use of AcGiViewportDraw::polylineDc() and AcGiViewport::getViewportDcCorners() to obtain the display coordinates of the viewport. This function is convenient when you are drawing graphics that depend on the physical layout of the viewport, such as icons and markers that vary with the size or borders of the viewport. The graphics drawn will change with panning and zooming.
The example draws a box in the upper-right corner of the viewport. The box's width and height are always one-tenth of the viewport's shortest dimension, and the box is centered one-tenth of the viewport's shortest dimension down and to the left of the upper-right-hand corner of the viewport:
void
AsdkIconSamp::viewportDraw(AcGiViewportDraw* pV)
// Get the current viewport's display coordinates.
AcGePoint2d lower_left, upper_right;
pV->viewport().getViewportDcCorners(lower_left, upper_right);
double xsize = upper_right.x - lower_left.x;
double ysize = upper_right.y - lower_left.y;
xsize /= 10.0;
ysize /= 10.0;
double xcenter = upper_right.x - xsize;
double ycenter = upper_right.y - ysize;
double half_xsize = xsize / 2.0;
double half_ysize = ysize / 2.0;
// Create a unit square.
const int num_verts = 5;
AcGePoint3d verts[num_verts];
for (int i = 0; i < num_verts; i++) {
verts.x = xcenter;
verts.y = ycenter;
verts.z = 0.0;
verts[0].x -= half_xsize;
verts[0].y += half_ysize;
verts[1].x += half_xsize;
verts[1].y += half_ysize;
verts[2].x += half_xsize;
verts[2].y -= half_ysize;
verts[3].x -= half_xsize;
verts[3].y -= half_ysize;
verts[4] = verts[0];
pV->subEntityTraits().setColor(kRed);
pV->geometry().polylineDc(num_verts, verts);
GMT+8, 2025-10-15 04:12 , Processed in 0.134343 second(s), 23 queries , Gzip On.
