查看: 2181|回复: 2
打开文件
发表于 2005-3-9 09:11:00 | 显示全部楼层 |阅读模式
如何在ARX中不通过文件对话框打开DWG文件并置为当前文档
发表于 2005-3-9 10:21:00 | 显示全部楼层
static char pData[] = "C:\\test.dwg";
void openSyncDoc()
AcApDocument* pDoc = acDocManager->curDocument();
if (pDoc)
acutPrintf("\nCurrently in Document context : %s, Switching to App.\n",pDoc->fileName());
acDocManager->executeInApplicationContext(openSyncDocHelper, (void *)pData);
acDocManager->activateDocument(pDoc);
acDocManager->closeDocument(pDoc);
void openSyncDocHelper( void *pData)
if (acDocManager->isApplicationContext())
acutPrintf("\nSucessfully Switched to App. Context\n");
acDocManager->appContextOpenDocument((const char *)pData);
acutPrintf("\nOpened a document synchronously:%s.\n", (const char *)pData);
else
acutPrintf("\nERROR: in Document context : %s\n",pDoc->fileName());
发表于 2005-3-10 10:48:00 | 显示全部楼层
acDocManager->appContextOpenDocument("你要打开的文件名和路径");只要打开后就置为当前了。我觉得这样做很简单,你可以试试
GMT+8, 2025-5-15 08:30 , Processed in 0.162764 second(s), 24 queries , Gzip On.
