查看: 1344|回复: 2
请问注册表的问题
发表于 2005-3-11 08:17:00 | 显示全部楼层 |阅读模式
在VBA中如何写入注册表信息呢?
请举个实例说一下吧
谢谢
发表于 2005-3-11 11:55:00 | 显示全部楼层
SaveSetting和GetSetting
发表于 2005-3-17 16:52:00 | 显示全部楼层
不妨参考如下代码: 首先声明相关API调用
Public Const HKEY_CURRENT_USER = &H80000001
Public Const REG_SZ = 1
Public Declare Function RegOpenKey Lib "advapi32.dll" Alias "RegOpenKeyA" (ByVal hKey As Long, ByVal lpSubKey As String, phkResult As Long) As Long
Public Declare Function RegQueryValueEx Lib "advapi32.dll" Alias "RegQueryValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal lpReserved As Long, ByVal lpType As Long, ByVal lpData As String, lpcbData As Long) As Long ' Note that if you declare the lpData parameter as String, you must pass it By Value.
Public Declare Function RegSetValueEx Lib "advapi32.dll" Alias "RegSetValueExA" (ByVal hKey As Long, ByVal lpValueName As String, ByVal Reserved As Long, ByVal dwType As Long, ByVal lpData As Any, ByVal cbData As Long) As Long ' Note that if you declare the lpData parameter as String, you must pass it By Value.
Public Declare Function GetVolumeInformation Lib "kernel32" Alias "GetVolumeInformationA" (ByVal lpRootPathName As String, ByVal lpVolumeNameBuffer As String, ByVal nVolumeNameSize As Long, lpVolumeSerialNumber As Long, lpMaximumComponentLength As Long, lpFileSystemFlags As Long, ByVal lpFileSystemNameBuffer As String, ByVal nFileSystemNameSize As Long) As Long
Public Declare Function DiskID32 Lib "XRID.DLL" (ByRef DiskModel As Byte, ByRef DiskID As Byte) As Long
后编写代码如下,即可: Dim i As Long, j As Long, k As Long, RegCode As String RegCode = "Registry Test"
i = RegOpenKey(HKEY_CURRENT_USER, "SoftWare", j)
i = RegOpenKey(j, "XX工作室", k)
i = RegOpenKey(k, "XXCAD信息", j)
i = RegSetValueEx(j, "序列号", 0, REG_SZ, RegCode, Len(RegCode))
GMT+8, 2025-5-4 19:31 , Processed in 0.163930 second(s), 23 queries , Gzip On.
