查看: 3817|回复: 7
[求助]如何生成闭合多段线?
发表于 2005-3-19 20:17:00 | 显示全部楼层 |阅读模式
类似CAD自带的边界图案填充命令,拾取点或选择对象时生成闭合多段线,但是源对象不要删除,遇到圆弧时自动用一定数量的线段来代替,线段的长度由用户输入。应该如何编写,或者提供一下思路。
发表于 2005-3-23 08:16:00 | 显示全部楼层
Just for your reference...It's a reply from Joe Parker Re: Create Boundary
counting the modelspace objects before and after a call to this sub will
tell you if there are any new polylines created- messy but it works
Private Sub Bound()
Dim Pt As Variant, gotpt As Boolean
gotpt = False
Do
On Error Resume Next
Pt = ThisDrawing.Utility.GetPoint(, "Select an Internal Point")
If Err Then
If GetAsyncKeyState(VK_ESCAPE) And &H8000& Then
Exit Function
End If
Err.Clear
gotpt = False
Else
gotpt = True
End If
Loop While Not gotpt
On Error GoTo 0
ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary" & vbCr & Pt(0) & "," &
Pt(1) & vbCr & vbCr
End Sub
 楼主| 发表于 2005-3-23 20:22:00 | 显示全部楼层
GetAsyncKeyState这个函数没有定义
发表于 2005-3-23 22:16:00 | 显示全部楼层
Option Explicit
Private Const VK_ESCAPE = &H1B
Private Declare Function GetAsyncKeyState Lib "user32" _
(ByVal vKey As Long) As Integer Private Sub Bound()
gotpt = False Do
If Err Then
Exit Sub
End If
Err.Clear
gotpt = False
Else
gotpt = True
End If
On Error GoTo 0
ThisDrawing.SendCommand Chr(3) & Chr(3) & "-boundary" & vbCr & Pt(0) & "," & _
Pt(1) & vbCr & vbCr
End Sub
 楼主| 发表于 2005-3-24 19:41:00 | 显示全部楼层
多谢版主的回复,但是程序只相当于正常的边界命令,还达不到我的要求,能否改进一下?谢谢!
 楼主| 发表于 2005-3-30 22:46:00 | 显示全部楼层
怎么没人知道吗?
 楼主| 发表于 2005-4-10 20:51:00 | 显示全部楼层
再顶一次。
发表于 2020-3-29 23:09:46 | 显示全部楼层
NNWS神速神速
GMT+8, 2025-5-23 05:47 , Processed in 0.206432 second(s), 28 queries , Gzip On.
