- 积分
- 3293
- 明经币
- 个
- 注册时间
- 2003-1-17
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
把ACAD.PGP里面的
START, START, 1,*Application to start: ,
修改为
START, START, 0,*Application to start: ,
即可。
修改后要执行命令REINIT,重新加载PGP文件。
相关内容请看ACAD.PGP。
; -- Command Aliases -- ; You can abbreviate frequently used AutoCAD commands by defining ; aliases for them in the command alias section of acad.pgp. ; You can create a command alias for any AutoCAD command, ; device driver command, or external command.
; Recommendation: back up this file before editing it.
; External command format: ; <Command name>,[<DOS request>],<Bit flag>,<rompt>,
; The bits of the bit flag have the following meanings: ; Bit 1: if set, don't wait for the application to finish ; Bit 2: if set, run the application minimized ; Bit 4: if set, run the application "hidden" ; Bit 8: if set, put the argument string in quotes ; |
