- 积分
- 536
- 明经币
- 个
- 注册时间
- 2005-1-28
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼上版主的想法有一个BUG,如果在一个封闭图形中还有一个或多个封闭的图形,那样只返回最外形框的面积而不能取得除去中间孤岛后的真实面积,我曾经写了这样一来一个程序,是用来计算铣加工体积的,有排除孤岛的功能!
(defun c:volm(/ p1 p2 ssa sst j sstx sstname area deep enaa item maxarea addarea qq emdh);;;计算铣深积 (setvar "cmdecho" 0) (setvar "osmode" 0) (command "ucs" "w") (setq p1 (getpoint "\n选取需要计算面域内一点(图元内最好无其他图元):") p2 (polar p1 (* 0.25 pi) 0.5)) (setq i 0) (setq enaa nil) (while (not enaa) (foreach item (ap-sslist (ssget "f" (list p1 p2))) (if (OR (= "LINE" (cdr (assoc 0 (entget item)))) (= "LWPOLYLINE" (cdr (assoc 0 (entget item)))) (= "POLYLINE" (cdr (assoc 0 (entget item)))) (= "ARC" (cdr (assoc 0 (entget item)))) (= "REGION" (cdr (assoc 0 (entget item))))) (SETQ enaa item)) ;(command "erase" item "")) ) ;(not (ssget "f" (list p1 p2)))) (setq i (1+ i)) (if (> i 4000) (exit)) (setq p2 (polar p2 (* 0.25 pi) 0.5)) ) (if (= "REGION" (cdr (assoc 0 (entget enaa)))) (progn (command "explode" enaa "") (hy_apline (entlast))) ) (setq ena (entlast)) (command "bpoly" p1 "") (setq sst (ap-after ena));;;;;;最后生成的所有图元 (setq qq 0) (repeat (sslength sst) (setq emdh (ssname sst qq)) (if (= "REGION" (cdr (assoc 0 (entget emdh)))) (ssdel emdh sst) ) (setq qq (1+ qq)) ) (setq j 0) (setq sstx (ssadd)) (repeat (sslength sst) (setq sstname (ssname sst j)) (if (vlax-curve-isclosed (vlax-ename->vla-object sstname)) (setq sstx (ssadd sstname sstx)) ) (setq j (1+ j)) ) (setq k 0) (setq maxarea 0) (setq addarea 0) (repeat (sslength sstx) (setq addarea (+ (vla-get-area(vlax-ename->vla-object (ssname sstx k))) addarea)) (if (> (vla-get-area(vlax-ename->vla-object (ssname sstx k))) mazrea) (setq maxarea (vla-get-area(vlax-ename->vla-object (ssname sstx k)))) ) (setq k (1+ k)) ) (setq area (- maxarea (- addarea maxarea))) (foreach item (ap-sslist sstx) (vla-put-color (vlax-ename->vla-object item) 50)) (command "hatch" "s" sstx "")(setq sstx (ssadd (entlast) sstx)) (setq deep nil) (while (not deep) (setq deep (getreal "\n请输入深度:"))) (alert (strcat "\n你选取部分的体积为:" (rtos (* deep area) 2 3))) (command "erase" sstx "") (prin1) ) 其中有调用一些公共函数一起奉上!大家可以交流一下是否还有更方便的办法!
(defun hy_apline(ename1 / vla-obj endpoint ename startpoint i ss1 nn ssm ssn itemx);;;选择一条线串接与之相联的图元为多义线 (if (= "LWPOLYLINE" (cdr(assoc 0 (entget ename1)))) (command "._explode" ename "")) (setq ename (entlast)) (setq vla-obj (vlax-ename->vla-object ename)) (setq startpoint (vlax-curve-getstartpoint vla-obj) endpoint (vlax-curve-getendpoint vla-obj)) ;(safearray-value(vlax-variant-value(vla-get-endpoint vla-obj)))) (if (OR (= "POLYLINE" (cdr(assoc 0 (entget ename)))) (= "LWPOLYLINE" (cdr(assoc 0 (entget ename))))) (setq i 1)(SETQ I 0)) (setq j 0);;计数器归0 (setq nn 0) (princ " ─── \r") (while (> (distance startpoint endpoint) 0.0000001);(= (vla-get-closed vla-obj) :vlax-false) ;(setq ss1 (ssget "x" (list (cons -4 "<or") (cons 10 endpoint)(cons 11 endpoint) (cons -4 "or>")))) (setq ss1 (ssadd)) (setq ssn (ssget "f" (list endpoint (polar endpoint 0.8 0.1)))) (foreach itemx (ap-sslist ssn) (if (or (< (distance endpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001) (< (distance endpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001)) (setq ss1 (ssadd itemx ss1)) ) ) (setq ss2 (ssadd)) (setq ssm (ssget "f" (list startpoint (polar startpoint 0.8 0.1)))) (foreach itemx (ap-sslist ssm) (if (or (< (distance startpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001) (< (distance startpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001)) (setq ss2 (ssadd itemx ss2)) ) ) (setq ssg (addss ss1 ss2)) (if (= 0 i)(command "pedit" ename "y" "j" ssg "" "") (command "pedit" ename "j" ssg "" "")) (setq ename (entlast)) (setq vla-obj (vlax-ename->vla-object ename)) (setq startpoint (vlax-curve-getstartpoint vla-obj) endpoint (vlax-curve-getendpoint vla-obj)) (setq i (1+ i)) (setq nn (1+ nn)) (cond ((= nn 15)(princ (strcat "线很长..正在串接中,请稍侯 ...... ───" "\r"))) ((= nn 30)(princ (strcat "线很长..正在串接中,请稍侯 ...... ﹨﹨﹨" "\r"))) ((= nn 45)(princ (strcat "线很长..正在串接中,请稍侯 ...... │││" "\r"))) ((= nn 60)(princ (strcat "线很长..正在串接中,请稍侯 ...... ∕∕∕" "\r"))) ) (if (> nn 60) (setq nn 1)) (setq j (1+ j)) (IF (and (= 1 (sslength ssg))(= (vla-get-closed vla-obj) :vlax-false)) (setq startpoint '(0 0 0) endpoint '(0 0 0)));(alert "\n请注意!****串接不线不能封闭!") ) (if (> j 1000)(prompt (strcat "\n恭喜你一共把" (itoa (+ (* 2 j) 3)) "条线串接成了一个封闭的復线!"))) ) |
